measuring dc voltage higher than supply
I would like to be able to read a dc voltage that is higher than the supply used for the basic stamp.
Infact they will be separate supplies.
I assume the first step is to tie the grounds together.
I am talking 60vdc or so but I assume the principle will be the same.
I have seen howto's on RC time and voltage dividers but the all seem to revolve around essentially measuring the supply feeding the circuit board. ie for monitoring the battery supplying the project.
Can anyone point me to a howto or give me some pointers. I think it would be nice to have some isolation strategy.
Rich
Rich
60V can be dangerous, BTW.
Accuracy well 1 volt would do but half or tenth of volt would be nice just because one can.
Does this change the approach?
Cheers
Rich
On the other hand, if you use resistors that are too high, then you might get into troubles with temperature dependency, etc. Using 10 Mega Ohm resistors would NOT be the answer.
You need to find a "safe" level of current you can draw from your source without frying the resistors or sagging the power supply or taking forever for your RC circuit to charge up, etc.
I'm just guessing that something in the 10K to 50K range would probably be a design point to begin with, but crunch through the numbers to see what your system can deal with.
Hope that helps,
http://www.sparkfun.com/commerce/product_info.php?products_id=9028
Other projects preempted but you might check out their approach.
I was pumping 48V at 60amps
