Parallax servo controller without firmware
Hey,
I have a parallax USB servocontroller that i want to use in conjunction with my basic stamp 2, but it doesnt have any firmware and its not responding to the software from the parallax website. anyone have any idea how i install firmware on this thing and what could be the cause of it not functioning together with the software?
greets.
greets.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/595/Default.aspx
If it is the old style, I don't believe you can reload the firmware. How do you know it does not contain the firmware? Maybe the board is dead?
Jim
i have the 28823 usb servo controller, and i did check out the firmware versions on the parallax website, but i dont know how to upload them to the controller. how do i know its dead? i mean everything seems to light up, the red and green led seem to work.
how do i know it doesnt have firmware installed, i checked it with the serial code first that came in the manual:
' {$STAMP BS2} ' {$PBASIC 2.5} Sdat PIN 15 ' Serial Data I/O pin Baud CON 396 ' Constant for 2400 baud buff VAR Byte(3) ' temporary variable FindPSC: ' Find and get the version DEBUG "Finding PSC", CR ' number of the PSC. SEROUT Sdat, Baud+$8000, ["!SCVER?",CR] SERIN Sdat, Baud, 500, FindPSC, [STR buff\3] DEBUG "PSC ver: ", buff(0), buff(1), buff(2), CRno result it just keeps spitting ' Finding PSC' and no number.
i also installed the 'PSCi Software for PC' software and used its tools to check for firmware, all it shows are a number of dots, no number either.
does that mean its dead, or empty?
Download the firmware and unzip it to a folder of your choice.
Open "PSC Propeller Firmware.spin" in the Propeller Tool
Insert USB cable into the controller.
Press F11 to download the firmware into the Propeller.
Test with the PSCI software first.
Jim
thanks.
http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerMediaPage/tabid/832/Default.aspx
It's the first download on the top. When prompted, install the FTDI USB driver, if you have not already done so. You will need it to talk to controller through the Spin Tool and PSCI.
Jim
error: no propellor chip found on any serial port.
hmmm, do you think its broken?
First..A new USB cable.
Second..Uninstall the FTDI drivers and the reinstall them. If you have an item in your control panel with a question mark, delete it. What OS are you running?
What is you total hardware setup?
Jim
im running windows XP
hardware setup, i have 1 scanner on com1, i have the basic stamp/servo controller on com3. nothing else besides my screen.
i have nothing of interest installed that could disable any communication with the servo controller.
i tried checking port status and data transfer with the PSCI and com3 status via hyper-terminal it is sending data. and every time i touch something on PSCI the little green light blinks, which i presume means its receiving something.
but when i try the propeller tool it cant find squat. i dont know, it looks to me that everything is working but my servo controller is just brain dead. i need to somehow get the firmware on it. just cant get it to respond.
You should not have the Basic Stamp and the Servo Controller on the same Com Port. XP should assign a different Com Port to the Servo Controller, as it's FDTI USB chip has a different and unique serial number.
It should have shipped from the factory with the firware installed.
Jim
i dont remember if it had firmware already installed when i bought it, it just worked then, not anymore though.
im just going to have to work with the basic stamp and see if i can get this puppy sent back for checkup or something, dont know if that is possible since i bought mine in 2005.
This is the old one, not the new one.
Rich H
Rich, you are correct. We are dealing with the old controller. I read the part number wrong on my aging monitor in my dusty workshop.
That changes everything. I'll reread everything and get back to a BS2 state of mind.
Jim
Clearly it had firmware installed at first, since it worked. If it's a hardware failure, I would contact Parallax to see what it would take to repair.
Jim
