BWT I have two of these I bought another one to take apart and use in a project here is why
...........................................(PIR)..........................................................................................................................
One thing I see with this (Inferred LED )sensor is that it only start the pump for moment and then it wait until you move hand again then it runs the pump again and so on also you have to have your hand real close to the dispenser for it to do any thing which is real nice for it to be like this because you do not waste any soap
Look like we are both wrong it is an Inferred LED sensor not a PIR sensor that dose it
Here are the photos of the board it draw about 370 milliamps when the pump is running When it is not running I do not know this yet
One thing that I am going to try is to see how far apart I can have these sensors and they still work right
Look like we are both wrong it is an Inferred LED sensor that dose it there are the photo of the board it draw about 70 milliamps when the pump is running When it is not running I do not know this yet
I think that they use something like one of those Sharp IR proximity detectors. It's one of the applications they mention in the data sheet. It would have to be a lot cheaper, though.
I do not know if it is because it has a 2 Pin something in a black plastic tube the top sensor shine on it when you move the sensor a way that what make the pump run both Sensor are 2 pins
It's the GP2D120. What you have seems different, though.
Coincidentally, I'm watching TV whilst using the laptop and I've just seen a commercial for a similar soap dispenser: it's called the Dettol No-Touch Hand Wash System.
PIR is a specific type of IR sensing that is very sensitive to overall changes and easily sees body heat, but can't tell much else. Some IR sensors are arranged in arrays that can determine direction of movement; others can be calibrated for temperature readings.
I just tried out the Propeller Capacitive Touch sensor program and this works without even touching the pad if you have the sensitivity set to very sensitive. You can just hold your finger/hand near the sensor and that will trigger the capacitive sensor "switch".
Jim
Jim
Here is a thread on that...
http://forums.parallax.com/showthread.php?t=117718&highlight=capacitive+touch
(More threads you can search for...)
