Product: LISY300 module in SIP configuration
Roy Eltham
The current LISY300 module has a DIP configuration. This means it can only be used to track Yaw rotations easily.
If we had a SIP version (similar to the xbee SIP module or some other SIP modules you sell) then we could set it up to measure pitch or roll rotations.
I have tested the module on a board turned sideways, and it works just fine for roll or pitch.
Another option would be to provide a module with a different chip that measures pitch or roll when mounted flat like the current LISY300.
http://invensense.com/mems/gyro/itg3200.html
http://www.sparkfun.com/commerce/product_info.php?products_id=9793
I have seen it for as little as $10.00.
Jim
