Simple Code not working? — Parallax Forums
XetarXetar Posts: 10
edited 2010-10-26 14:42 in Propeller 1
In the following code, the variable: "long[pValue]" never changes from zero. I'm assigning it a value from my LTC1298 with this line "long[pValue] := gblAD1.GetADC(0)"
I have verified that the cog is working, if you look you will see a line commented out that just increments the value. This works an the value goes up accordingly. However when I replace it with the call to my A2D chip, all i get is 0.
If I move the A2D chip code to my primary cog, I see the value just fine. Any idea what i'm doing wrong here?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
LONG gblA2D_Cog
LONG SqStack[20]
obj
gblAD1 : "CD_LTC1298" 'A2D driver
PUB StartProcess(pValue)
gblA2D_Cog := cognew(Process(pValue), @SqStack)
PUB Process(pValue)
' Initialize the A2D driver
gblAD1.start(0)
repeat
' Get the A2D reading
' long[pValue]++
Waitcnt((clkfreq / 10) + cnt)
PUB StopProcess
if gblA2D_Cog
cogstop(gblA2D_Cog~ - 1)
    edited 2010-10-26 14:06
    Xetar - I tried this and it seems you need to increase your SqStack amount a bit then it works. You can archive your whole code to post here in the file menu in the propeller tool.
  • train nuttrain nut Posts: 70
    edited 2010-10-26 14:18
    I may be wrong but I believe that "long" is a reserved word in spin and cannot be used as a variable.
  • XetarXetar Posts: 10
    ratronic wrote: »
    Thanks that did the trick. And I'll try the archive thing next time.
