Midi Out Isolation Chip
is a darlington or an opto better for the prop to Midi out? 3.3V to 5V I don't think using the darlinggton is bad but is the opto a better solution? The MIDI spec shows 2 inverting buffers. Anyone have a standard they use for the prop to MIDI out?
Are you talking about input or output.
For output you can have a look at the schematic in this post:
http://forums.parallax.com/showthread.php?t=118144&highlight=midi
For input you could use
4N28 optocoupler = NTE3093 Optoisolator or a use a TOSHIBA Photocoupler:
http://www.semicon.toshiba.co.jp/docs/datasheet/en/Opto/TLP552_en_datasheet_090217.pdf
and a 74HC14 for output. You can also use 2 resistors for the output -
but if you want to be on the safe side, I'd recommend the hex inverting
schmitt trigger (74HC14).
