Trying to Access a global variable from with in a object.
I'm trying to access a global variable from with in a object.
When all the code is in one file. It works as expected.
This outputs what I expect. I have 0's when the button is not pressed, and 1's when it is.
The problem comes into play when I put the OtherCog in a separate object/file.
File:test_global1.spin
File:test_global2.spin
The value is 15 when run.
I'm new to the propeller and micro controllers in general.
what am I missing?
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
SerCon_Tx = 8
SerCon_Rx = 9
VAR
long Stack[14]
long GlobalVar1
OBJ
SerCon : "FullDuplexSerialPlus"
PUB init
cognew(OtherCog, @Stack)
dira[16] := 0
repeat
if(ina[16] <> 0)
GlobalVar1 := 1
else
GlobalVar1 := 0
PUB OtherCog
' Serial Console port
SerCon.start(SerCon_Tx, SerCon_Rx, 0, 57600)
SerCon.str(string(" ",SerCon#CR,SerCon#LF))
SerCon.str(string(" Serial Console started.",SerCon#CR,SerCon#LF))
repeat
SerCon.dec(GlobalVar1)
waitcnt(100*(clkfreq/100) + cnt)
CON
VAR
long GlobalVar1
OBJ
G2 : "test_global2"
PUB init
G2.init
dira[16] := 0
repeat
if(ina[16] <> 0)
GlobalVar1 := 1
else
GlobalVar1 := 0
CON
SerCon_Tx = 8
SerCon_Rx = 9
VAR
long Stack[14]
long GlobalVar1 'Will not compile without this.
OBJ
PUB init
PUB OtherCog
repeat
what am I missing?
cognew(OtherCog(@GlobalVar1), @Stack)
PUB othercog(TheVarToAccess) long[TheVarToAccess] := ???Then, in the othercog, access the var with long[TheVarToAccess]
Typically this is handled by passing the address of a variable in the outer object (test_global1.spin) as a parameter to the initialization routine in the inner object (test_global2.spin) and saving the address of this variable in a variable in the inner object like:
With the amount of variables I'm working with I'll probably just move it back into one object.
If you are suggesting that you would have to add a lot of parameters, that is not the case. You only need to point to the first variable in the line. Then access the following longs by +4. If using words or bytes, adjust the math accordingly.
VAR long1,long2,long3 'do not change this line or it will affect the var access in the cog cognew(OtherCog(@long1), @Stack) PUB othercog(TheVarToAccess) | x, y , z x := long[TheVarToAccess] y := long[TheVarToAccess+4] z := long[TheVarToAccess+8]
