Wave audio noise. — Parallax Forums
Wave audio noise.
SexieWASDSexieWASD Posts: 41
edited 2010-10-25 02:28 in Propeller 1
I've been designing a pumpkin this weekend for Halloween. I got Wave audio playback on my uOLED-96-prop with Raymond Allen's PlayWav_16bitStereo.spin, however the sound is quite horrible, I had it running through a LM386N amp, but even directly (except one resistor) into my amplified PC speakers it has a ton of noise. I was wondering what other people have done to either filter or eliminate the noise. It sounds scratchy yet digital, if that makes sense. <-edit: (a lot like bad clipping actually)
I'm sorry if this has been covered already, I've been searching all day for a way to fix it, but haven't had any luck so far.
  • JonnyMacJonnyMac Posts: 9,692
    edited 2010-10-24 14:08
    I went through this with a commercial product (AP-16+) and Chip Gracey identified the issue and solved it with a small cog. Instead of writing directly to the DACs you write to the hub and let the Stereo_Duty cog take care of the output.
    You can find a demo that fixes the noise issue you're encountering in this thread:
    -- http://forums.parallax.com/showthread.php?t=123900
    edited 2010-10-24 17:05
    JonnyMac wrote: »
    I'm curious. Which pins is the AP-16+ using for audio out?
  • SexieWASDSexieWASD Posts: 41
    edited 2010-10-24 17:52
    This is awesome, I've now got it outputting some decent sounding audio clips. I am amazed at this fix, I really had no chance of fixing that on my own.
    @kuroneko
    This line in efx_wavdacs_demo_sd.spin is what I changed to set the pins, by default it's pins 11 and 10.
    duty.start(@lrsamples, 11, 10)                                ' launch duty into cog 1
    Now all I have to do is figure out why it plays the clip twice...
    EDIT: nvm fixed that too, this pumpkin is going to be sweet!
    edited 2010-10-24 17:57
    SexieWASD wrote: »
    Ah, should have read more comments (too early here). Seems that the AP uses the same pin locations as the demo board. Thanks.
  • kellyj994kellyj994 Posts: 1
    JonnyMac wrote: »
    Thanks you for the post.
