Ideas on how to make a Propeller controlled VFO
I'm working on a project where I would like to vary the frequency of the 120V AC line from 60hz. I would need a range of about +- 15hz.
I like to use the propeller if possible so that the freq could be digitally controlled and selected, then shown on a small display.
Any ideas on the best way to approach this?
One way I've heard of is to generate a audio tone, feed it into a small audio amp and use a transformer to take the audio output and recreate 120V.
Not sure this is really the best way, or if there are modules that the propeller can easily interface to that would let me do what I need.
Any ideas would be very much appreciated!
Yes, I don't intend to alter the incoming line, I want to generate an outgoing 120V signal that has variable frequency.
Power output would be around 10 watts or so. I would think that the 120V output would be isolated from the propeller, but its not a requirement.
