Battery pack for a protoboard?
gmiller
I just picked up a protoboard USB and the accessory kit. I'll be using it as a project for my "Intro to ECE" lab (basically, demonstrating that I can solder something with at least 10 parts together, which is where the accessory kit comes in). I have one of the Parallax 7.5v AC adapters, but due to lab safety rules, it'd be a lot easier if I power it from a battery pack.
Any suggestions for a battery pack that could be acquired locally (from a Radio Shack or Electronics Express, for example)? Rechargeable or not rechargeable is fine, since I just need something for a one shot demonstration while not plugged in.
So the physical connector and everything are standard? I'm pretty new to all this.
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=274-1569&origkw=274-1569&sr=1
It's a 5.5mm barrel with a 2.1mm female center opening.
Jim
http://www.radioshack.com/product/index.jsp?productId=2919620
GRAB IT!
I got one and soldered the above connector on it, (none of the supplied ones fit). It runs my Propeller and BS2 boards for days! They are blowing them out for $4.97!
Jim
+1 for LiPo's.
Jim
Radio Shack refers to the 2.1x5.5mm connector as type "M" and they usually have a ring with a sample of each connector available for you to try out.
cheers ... BBR
He may still have some available. If not, I could probably be persuaded to send one to you - PM me, if Bean doesn't have any more.
Art
