DIY project cabling options
I've officially started the "new and improved" rev. B of my piggyback board. On the original design, I had a 10-conductor ribbon cable going to the 4x7 segment LED displays (using six-conductors). Now I'm reviewing options for that. I like using cable types we all seem to have in our junk drawers even though the usage is non-standard. I have a lot of RJ-11 cables but none of them carry all six available conductors (RJ-25 6P6C). Second on the scrap list is left over RJ-45 cables. If I use RJ-45 board connectors then I have an interface with the locking tab easily ported through the side of the enclosure. Also if I wished to have data-out feed back from my serial displays the RJ-45 style would have an available wire for that. I've broached this type of discussion before so I have to be thick-skinned enough to hear how dumb this idea is, and why. Thing is, the parts count for such an inclusive multi-function board is getting higher and I'm concerned about the over-all parts total cost. I don't want the cost to go above what wage-earners like me can realistically afford. I've nailed down what type of cabling and connectors I'll use on the other 75% of the I/O.
Everything is being built around this infra-structure now so I suppose I had better get used to it. Broken things = me having a job (mustn't grumble)
perhaps there is a way to route the connections on the jacks so that either cable can be used?
