GPS invallid data when serial port is connected
hey,
i'm trying to get the "PMB-688 GPS SiRF Internal / External Antenna" gps module to work.
it has a led that shows a status of the gps information if its valid or not.
So when i only have the power connected the led turns on after a minut, so it has vallid data.
Now when i connect the serial port, the led keeps flashing even after 30 minuts, so no valid data.
any ideas?
any ideas?
And yeah the device is at the exact same location ....
another problem is that i don't recceive a thing on the serial port ...
GPS's Data_out is the yellow wire. The LED stays up once it's acquired its sats. I get great reception with the unit sitting on a benchtop in the house - without using the external antenna.
and yeah i'm using the yellow wire as rx data
What's its comms requirement? Is it "TTL"?
i have the gps chip directly connected to the serial port /dev/ttyS2
It blinks while it's acquiring. Cold-starting, it took about 40secs to do that and then it stays on solid.
Maybe you have a bad unit, but it's more likely it's the interconnect. Everybody has to be on the same GND/V_ss.
PE - I'd be in there with a scope, seeing what's going on, but that's me.
But the wierd thing:
if i connect the unit to the foxboard no data is received
if i connect it to a usb to ttl convertor i get the output nicely ...
thats onaother wierd part
about vcc/gnd
its battery powered so everything is on the same power source
the foxboard defines:
so i gues si don't need a voltage convertor
Get that scope (or bring the beast in to work with you.)
-- You can always try some metering, too. --
what do you mean with that?
For instance, I know my data is good on my terminal, but I can also measure 2.4 - 2.8V (varying) on the Data_out pin showing that data is active.
