125kHz RFID Tag Emulator
Hey there,
I've just finished some proof-of-concept 125kHz RFID-Tag emulator
based on the Propeller. It emulates an RFID-Tag with 0xFFFFFFFFFF - binary 1111111111111111111111111111111111111111)
I haven't tryed it yet, but it should work.
Here's a circuit. You'll need an appropriate antenna of course (can be DIY - search for 125kHz Coil Antenna).
It sould be around 160uH. The transistor should be a NPN transistor.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 COIL_PIN = 4 WAIT = 4_728 ' So the ID gets transferred in exacty 32.761ms PUB main | chksum, i dira[COIL_PIN] := 1 outa[COIL_PIN] := 0 repeat i := 0 repeat 64 encodeManchester(0, id[i]) waitcnt(cnt+(CLKFREQ/WAIT+390)) encodeManchester(1, id[i]) waitcnt(cnt+(CLKFREQ/WAIT)) i++ waitcnt(cnt+(CLKFREQ*2)) PUB encodeManchester(clock, data) | encoded encoded := clock ^ data if(encoded == 1) outa[COIL_PIN] := 0 else outa[COIL_PIN] := 1 DAT ' Start squence B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 End id byte 1,1,1,1,1,1,1,1,1, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0 ,1,1,1,1,0, 1,1,1,1,0 ,1,1,1,1,0, 0,0,0,0,0
Keep up the good work, and I would love to see you build a working prototype. I can see the this being used in college dorms around the world to brute force other kids RFID door locks haha.
Ahem... I don't understand this circuit. Where does it get it's power? Shouldn't the LC-tank be between the collector and power supply? Should work then.
The RFID tag is powered by inductivity. This circuit was also used
in an article featured at Hackaday.
for a fixed version.
6581 said:
I don't know about you, but I've had a lot projects that "should work" but didn't on my first attempt.
Duane Degn
