Cannot play file from SD-card!
Hello there,
I've tried using the "Generalized WAV player" from the OBEX and I couldn't get any sound out from the speaker, despite the connections of the SD card are all made.
I used a 20K ohms pullups resistors, starting from P0, with pin 8 and 9 not connected to pullups. Also, I'm connecting the output to an LM386 with minimal components (gain = 20).
Upon inspection in the Serial Terminal, I found that the chip is not accessing the SD card at all! It hanged in there and didn't do anything.
Any ideas on how to get the SD-card working? I've tried two, and it gives me the same thing.
I'm using my SD-Card without any pull-up's - you could try that. But first, try another SD-Demo (fsrw)
The thing is, the program is in the form of a terminal program, and I can't get any thing on the screen at all. Must I use Hyperterminal, or the Parallax Serial Terminal? I can't get all of these to work at all.
Hello there,
I tried the BST as well just now. I couldn't get anything out of the screen and from the processor as well. I've even double-checked all the connections - they seem to be correct.
Right now I have to get some sound out from there, but I tried it without success for a whole day.
Yes sir, I get some sound from the included Ken Gracey's/Beau Schwabe's Frequency Generator program.
I believe it is my own SD Card's fault, or the program refuses to cooperate. I had to try that one more time.
