BS2 reset problem (solenoid-related)
I am doing a project with BS2 for driving 220V solenoid. I use relay between BS2 & solenoid.
The problem is sometimes my BS2 resets when I switch on/off the 220V solenoid.
The problem only occurs when I connect the solenoid to the relay. BS2 & relay (without solenoid) works perfectly. Based on that, can I assume that the problem is not "relay kick-back" issue?
I am also using ULN to interface between BS2 & relay. To power up BS2, I use switching supply.
Desperately need help.....Any advice?
Thx
Bronson
Thx
Bronson
Thanks for your quick reply.
In your opinion, is it more likely EMI/RFI problem or "relay kick-back" problem?
For additional info, at the BS2 board side (at power section), I do exactly like BOARD OF EDUCATION. Do I need to put additional filtering on that? If yes, pls tell me how.
What about bad ground plane of PCB? Could it be the culprit?
The ULN drivers have a built-in "snubber" diode so it's unlikely that you're getting relay "kickback". Also, you're not getting the problem when the solenoid is disconnected.
I just did a test to my board. If I turn off the board for approx 0.5sec then turn it on again, BS2 doesn't reset.
Base on that, can I say that it is not the power supply related-problem?
Thank,
Bronson
Thanks for your input. I will pay attention on that
Bronson
