I'm having trouble in a new cog.
I'm having trouble starting a new cog and having the code execute as I expect it. I'm driving 2 8x8 led arrays and basically making a countdown timer. It's choppy when the digit spans 2 displays. This is what works. Be gentle as this is my first real attempt at spin other than blinking LED's
I thought this would work but it didn't. basically same code but I thought I'd start a new cog and have it constantly run. I'd flag when that particular display needed refreshing and it would happen. Unfortunately, it doesn't.
Comments?
Best regards,
Fred
CON _CLKMODE=XTAL1+ PLL2X 'The system clock spec _XINFREQ = 40_000_000 'crystal spec BLUE = %00000011 GREEN = %00011100 RED = %11100000 _cs0 = 0 _clk0 = _cs0 +1 _mosi0 = _cs0 +2 _cs1 = 3 _clk1 = _cs1 + 1 _mosi1 = _cs1 + 2 _frame_size = 128 display = 32 black = 0 white = blue | green | red background = black foreground = red VAR byte array[_frame_size] byte idx byte bit byte time byte minute byte offset1 byte offset2 byte offset3 byte mask byte tens byte sec long digit long stack1[25] long stack2[25] long stack3[25] long stack4[25] byte ck, mo PUB Go DIRA[_cs0]~~ DIRA[_cs1]~~ 'osc once to set up 3202 DIRA[_mosi0]~~ 'data set up to the chip DIRA[_mosi1]~~ 'oscillates to read in data from internals dira[_clk0]~~ dira[_clk1]~~ outa[_cs0]~ outa[_cs1]~ outa[_cs0]~~ outa[_cs1]~~ cognew(send_frame_0, @stack1) cognew(send_frame_1, @stack2) bytefill(@array, foreground, _frame_size) send_frame_0 pause(1) send_frame_1 pause(1) bytefill(@array, background, _frame_size) send_frame_0 pause(1) send_frame_1 pause(1) 'idx :=0 show_digits pub show_digits array[byte[@colon]] := foreground array[byte[@colon+1]] := foreground send_frame_0 repeat minute from 3 to 0 digit := long[@number][minute] repeat offset3 from 0 to 31 mask~ mask := >| digit case mask 32: array[byte[@digit_address_1+offset3]] := foreground other: array[byte[@digit_address_1+offset3]] := background digit <<= 1 send_frame_0 repeat tens from 5 to 0 digit := long[@number][tens] repeat offset1 from 0 to 31 mask~ mask := >| digit case mask 32: array[byte[@digit_address_2+offset1]] := foreground other: array[byte[@digit_address_2+offset1]] := background digit <<= 1 send_frame_0 send_frame_1 repeat sec from 9 to 0 digit := long[@number][sec] repeat offset2 from 0 to 31 mask~ mask := >| digit case mask 32: array[byte[@digit_address_3+offset2]] := foreground other: array[byte[@digit_address_3+offset2]] := background digit <<= 1 send_frame_1 pub send_frame_0 outa[_cs0]~ repeat bit from 0 to (_frame_size / 2) SPI_byte_0(array[bit]) outa[_cs0]~~ pub send_frame_1 outa[_cs1]~ repeat bit from (_frame_size / 2) to _frame_size SPI_byte_1(array[bit]) outa[_cs1]~~ pub SPI_byte_0(char) outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %10000000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %01000000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %00100000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %00010000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %00001000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %00000100) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %00000010) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (char.byte[0] & %00000001) <# 1 outa[_clk0]~~ pub SPI_byte_1(char) outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %10000000) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %01000000) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %00100000) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %00010000) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %00001000) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %00000100) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %00000010) <# 1 outa[_clk1]~~ outa[_clk1]~ outa[_mosi1] := (char.byte[0] & %00000001) <# 1 outa[_clk1]~~ pub pause(ms) waitcnt((clkfreq/1000)*ms + cnt) dat number zero long %00000110100110011001100110010110 one long %00000010011000100010001000100111 two long %00001111000100011111100010001111 three long %00001111000100011111000100011111 four long %00001001100110011111000100010001 five long %00001111100010001111000100011111 six long %00000010010010001111100110011111 seven long %00001111000100100100010001000100 eight long %00000110100110010110100110010110 nine long %00001111100110011111000100010001 frame_dat byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 byte $00,$00,$00,$00,$00,$00,$00,$00 digit_address_1 byte 0,8,16,24,1,9,17,25,2,10,18,26,3,11,19,27,4,12,20,28,5,13,21,29,6,14,22,30,7,15,23,31 digit_address_2 byte 56,64,72,80,57,65,73,81,58,66,74,82,59,67,75,83,60,68,76,84,61,69,77,85,62,70,78,86,63,71,79,87 digit_address_3 byte 96,104,112,120,97,105,113,121,98,106,114,122,99,107,115,123,100,108,116,124,101,109,117,125,102,110,118,126,103,111,119,127 colon byte 42,46
pub send_frame_0 repeat if display0 == true outa[_cs0]~ repeat bit from 0 to (_frame_size / 2)-1 outa[_clk0]~ outa[_mosi0] := (array[bit] & %10000000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %01000000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %00100000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %00010000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %00001000) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %00000100) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %00000010) <# 1 outa[_clk0]~~ outa[_clk0]~ outa[_mosi0] := (array[bit] & %00000001) <# 1 outa[_clk0]~~ outa[_cs0]~~ display0 := 0This is started as in the first code example.
Comments?
Best regards,
Fred
Initialize the appropriate bits of the DIRA register during the initialization of the cog methods (send_frame_0 and send_frame_1).
I'm not sure what kind of problems show up with too high an input frequency.
Jim
