3ph PWM signal
Hello,
I want to use PWM and generate 3 signals 120 degrees apart to control my DC to 3 Phase AC inverter i have been working on. I have a few circuits that are not using a micro but I would like more control over the PWM signals a micro would have.
I have looked into the samples for PWM but I dont see how i could use them to make the 3 signals i need 120 degrees apart. Thanks for any help.
Did you search in the Object Exchange (OBEX)? I think Beau has what you need (see link below), but there might be others, too. Look at the PhaseSync method in the following:
http://obex.parallax.com/objects/467/
hope that helps,
