Propeller Professional Development Board Power Supplyh
Hello all,
A couple of questions on the power supply for the Prop Dev Board:
1. Can someone link me to the Parallax product page for this power supply? I am having a heck of a time trying to find it.
2. I have a whole bag of adapters here and I'm sure I have one that meets the requirements for powering this board. What can I do to make sure that one that I pull out of the bag is appropriate? I saw the voltage requirements but I also saw some warnings about overpowering or something. Do I simply check that the voltage is within range even when the supply isn't loaded? How do I ensure that voltage won't dip too far when it is loaded? I have a volt meter to test with.
Shaun
Shaun
http://www.parallax.com/Store/Accessories/PowerSupplies/tabid/165/CategoryID/39/List/0/SortField/0/Level/a/ProductID/73/Default.aspx
12 VDC 1 amp
http://www.parallax.com/Store/Accessories/PowerSupplies/tabid/165/CategoryID/39/List/0/SortField/0/Level/a/ProductID/75/Default.aspx
I would suggest checking any supply you have with your multimeter before hooking it up to a board just to make sure it hasn't gone crazy.
Try this
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/75/Default.aspx?txtSearch=power+supply
2.1mm jack center + POS....outer is - NEG
With a voltage of 6volt DC to ~20volts DC and at least 1 amp
I plugged it in and turned on the board. It now reads 15.04V across the ground and input pins of the LM1086 regulator. Looked at the output of the regulator and that was 5.05V or so. The output of the downstream regulator was something like 3.32V.
These regulator outputs sound correct so I'm thinking that my input voltages being higher than what I'm confident of should be ok. I haven't seen anything that was inconsistent with the LM1086 datasheet as far as input voltage or allowable voltage difference between input and output. I am thinking that the LM1086 would be the problem component in this chain if I went too high in voltage.
LM1086 datasheet: http://www.national.com/ds/LM/LM1086.pdf
I also just measured what the Propeller Education Kit regulators are putting out. The first one is putting out more than 6 volts and the second one is doing 3.33V. This gives me confidence that I am going to be alright.
I'm going to try it with the prop plugged in and hope that my due diligence here has protected me from damaging the board. I wonder why Parallax recommends the 7.5V 1 amp supply? I'm just a lowly mechanical engineer... maybe some of our electrical oriented friends can chime in here?
Shaun
A 7.5V "wall-wart" results in only a 2.5V input excess and the heat dissipated would have to be only 2.5 to 3.7W, a bunch less.
That's why Parallax recommends the 7.5V power supply.
I'm still wondering why parallax recommends the 7.5 volt one. Maybe the regulator works less with 7.5 than with 12? Less heat dissipation?
Edit: Just saw the reply above. I'll respond in the next post for cleanliness.
OK, this is something along the lines of what I suspected. Sounds like I should be OK with what I'm using now, though. Please tell me if I'm wrong. The 5V regulator is a bit hot, but I bet the junction temp is still ok.
Just throwing that out there.
PE - Depending on the rating and the bulb and all, it could be like a meter, too. ("Hey, whatever just happened made the bulb dim out like...")
Can't really tell the temp of "a bit hot", But if you can keep your finger on the REGs you should be OK.
My voltage REGs run around 90'F with a lite load on the Prop. Pro DEV.Board.
I think you'll be OK with your wall-wart.(as long as you can keep your finger on the REG's with out getting burnt.)
Asking what might seem stupid questions will preserve the life of your Pro.Prop.DEV.Board.
Enjoy
