re: New Memsic MXD2125G/M Higher sample rate acceler
I noticed there is a new link on the Parallax Memsic 2125 product page that contains the spec sheet for the newer MXD2125G/M accelerometer with a higher x4 sample rate (400Hz) than the existing Memsic 2125 (100Hz) and lower noise LINK: [url]http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/MXD2125G&M.pdf[/url].
I noticed that at the bottom of the spec sheet that the product has been available at least from 3/25/2005 so I imagine that it is a mature product by now.
When do you expect to have a breadboard version available?
Thank you!
Thank you!
In regards to your question about creating a breadboard for the Memsic 2125GM. I believe we would update that IC to the H/N once we have exhausted our current stock (1400) of the G/Ms. I will bring this up to our engineering department to look at using the H/N once we go to build the next lot.
Thank you for the question and bring this up as a very good suggestion!
