help with xbee and board of education
I was wondering if anyone can help.
I have two xbee 1mW chips, on on usb adaptor board which is connected to and powered by my PC, the second is on a 5v/3.3volt adaptor board.
Everything works great when the second (adaptor board) xbee is powered by my professional development board (via vdd, 5 volts). The power supply to the development board is 12V, 500mA wall wart.
When I power the second xbee from my BOE (using the same 12V, 500mA wall wart) via vdd (which is at 5 volts), I get a gibberish transmission. When I power the BOE with a 9 volt battery, all is fine.
This happens with both of my 5v/3.3 volt adaptor boards for the XBee
The project I am working on needs a 12volt 500mA to 1000mA supply (there is a camera in addition to BOE which has several sensors). All of this works fine (ie, with regard to this BOE and this setup).
I would like the XBee to work with my project. I suspect it has something to do with the current from the BOE power supply with the wall walt relative to the 9 volt battery. Any ideas as to what is happening and what I can do?
fsb
fsb
I think you are right, the DC voltage isn't as regulated on the BOE as on the developer board.
However, after a period of time, no matter what board I use, the Xbees stop sending data (I am using the test loop described in the getting started with xbee draft pdf, chapter 3 which I found on the wireless forum).
Although the blue led lights up, no data is recieved back on the x-ctu terminal- but no gibberish. This is likely an xbee communication/network? issue, i am guessing.
I just got the Xbees. They are (or were) to replace my 433 mHz transceivers (which work fine).
Looks like i got a lot of reading ahead of me....
thanks
fsb
