$50 Chalenge
If anyone is interested I am offering $50 to a smart programmer capable of designing a network interface to the makerbot for under $50 part cost. There are no restrictions on what processor you use and a prop would be a great method in my opinion.
http://groups.google.com/group/makerbot/browse_thread/thread/951b32991857d341
for official posting.
They have 0.1" pins so you just need a simple breakout PCB with RJ45 jack, 5v, power, status leds. They're slightly chunky by modern standards but easier to interface to.
I'd be pleased to assist your effort any way you may find helpful.
I could draw up pcb designs for a motherboard using a prop. I would make the designs available under creative commons. What I would need is great programmers that could write the software. Any new version should have network accessibility in mind as it would be much more convenient then usb.
Here is a link to my Micro-Mendel design which will use the new Prop pcbs I announced today. http://forums.reprap.org/read.php?4,57039
Reprap have released a new V6 electronics that is a single pcb atmega based design for $145 IIRC which directly competes to where I am headed but I believe the prop can be cheaper and certainly better.
My design will use the newly announced "ModBlade" plus an add-on pcb for the Stepper Drivers (also announced). Parts are on order. However, I have not yet done any of the software. Obviously the prop is a magnificent choice for this project.
IMHO the Pmod connector is an excellent expansion connector, so mctrivia, may I suggest you do a WiFi module for this? There is already an ethernet module http://digilentinc.com/Products/Detail.cfm?NavPath=2,401,822&Prod=PMOD-NIC for $30. I am sure there is a lot of interest for a WiFi module, not just for RepRap, and with the connectors I have on order, simple cables to the Prop ProtoBoard or any other expansion pcb can be made easily and cheaply.
I have not thought about the pcb for the extruder heater & temp probe and the heated platform and temp probe, so Mathew, maybe you are interested in doing this pcb too?
I have cost reduced my version of the micro-mendel so it should be possible to build them much cheaper than at present.
Any controller for the extrudder should use some heavy duty mosfets. The MK5 is a really nice print head but draws a lot of power. I do remember seeing a wifi model some where similar to the pmodnic you linked. It was $100 or so IIRC.
I have also tried to reduce the plastics required as these are a significant cost currently.
Printheads and the electronics are the current weak points. The mendel seems over-engineered to me which is why I am using bushes instead of bearings - much cheaper.
The com port redirection software (called Serial/IP) is included free and only works with hardware that pays the license fees. There may also be a stand alone version for other vendors Serial/TCPIP converters.
I have used quite a few com port redirection programs over the years and many failed when there was direct port access involved, or programs working in DOS command prompt under windows, etc. Serial/IP has a very useful monitoring tool for watching the stream go back and forth, too.
There are other modules from Digi, Lantronix that do a similar thing, and you can probably buy those from Digikey. I might be wrong but the upcoming Spinneret could possibly be programmed to do the same thing (with suitable com port redirection software)
cheers
tubular
The part specified in the post
http://ucontroller.com/documentation/PropNICDoc.html
is the same one used in the HIVE. The PropForth team is bringing the part on line in the next couple weeks as the prop forth port to the HIVE hardware is completed. If you are interested in a FORTH kernel that talks to the ENC28J60 there should be something by November.
Support of the wiznet5100 is already ALPHA and I access the interaction forth prompt via a telnet session. Web-server support is a little further out.
