BS2 and Serial RFID Reader
Hi All,
In my current project setup I have a Serial RFID reader plugged into the BOE w/BS2. We are trying to read the RFID tags through the VB software posted at
http://forums.parallaxinc.com/forums/default.aspx?f=21&m=269675
Currently we can not get the software to read the tags once passed by the reader...
Thanks in advance
Thanks in advance
http://forums.parallax.com/showthread.php?t=103732&highlight=rfid+reader+software
This thread should be able to help you hook up the MAX232.
http://forums.parallax.com/showthread.php?p=640507
I don't think you can have the VB software read the RFID tag through a BOE though, but I could be wrong. Are you trying to have the BOE do somthing after the card is read or the computer do something?
On the RFID reader product page you can get some demo code that you should be able to modify or extract what you need. There is also a nuts and volts article you could check out.
Example: In this demo code you could replace the latch/lock function with your servo code.
http://www.parallax.com/Portals/0/Downloads/src/prod/RFID1.zip
