HMC6352 compass
I'm using the honywell HMC6352 compass for direction oo my robot which navigates my living room. It seems that the compass is very much affected by any metal objects withing a few meters, giving readings up to 45 deg in difference from one end of the room to the other.
Would anyone have ideas on how to "shield" my compass for more consistant readings ? Or had similar problems that they have overcome ?
http://www.ocean-server.com/download/OS5000_FAQs.pdf
Dave
The level of sensitivity to metal objects that you are describing is not typical of the HMC6352 when it is properly calibrated. I have two HMC6352 devices on two different boards and using a steel object weighing ~2 Lbs, I had to get within 8 - 10 inches of the sensor to even make a change of 2 degrees in the heading. If I alter the X and Y Offset values in EEPROM (calibration), I can make it very sensitive to small changes in the magnetic field in certain directions.
I would suggest that you try and re-calibrate your sensor bsing careful to keep it level during the calibration and see if this helps. It is hard to imagine how the walls of your home could effect the magnetic field significantly at a few meters distance. Is your sensor being driven by a Boe-Bot or a Propeller application? If you are performing the calibration with an external power source and a USB cable attached, moving these cables over the sensor while you are rotating it can also induce errors in the calibration.
Hope this helps.
DAVX2120
I don't have the usb cable, or any other cables attached when calibrating.
The motors on the boe bot are only small, and should be far enough away not to affect the compass.
I migh try mounting it on my BS2 education board and see what the results are.
Thanks for the advice.
