inserting number into string
pgbpsu
How can I insert a number into a string?
I have a device that I can put to sleep using a serial port. The following command works just fine:
But I want to sleep the device for differing amounts of time. I'd like to be able to replace the 86400000 with a number of my choice. Here's what I've come up with, which doesn't seem to work by the way:
Here's what I get:
The hex values actually look fine so I'm not sure why it doesn't work. Maybe the question I should be asking is how can I spit out the hex characters for the string (at top) that does work?
And is there a simpler way to do this?
Peter
uarts.str(port,string("$PRTHS,COMA,86400000",CR,LF))
len := strsize(Num.ToStr(mSeconds, Num#DEC))
uarts.str(debug,string(13,"len: " ))
uarts.dec(debug,len)
uarts.putc(debug,CR)
bytefill(@sleepString,0,25) ' init sleep string
bytefill(@msString,0,10) ' init ms string
bytemove(@sleepString,@comaString,12) ' copy first part ($PRTHS,COMA,) into string
bytemove(@msString,Num.ToStr(mSeconds, Num#DEC),len) ' convert dec into string and store
bytemove(@sleepString[12],@msString[1],len-1) ' copy dec-string into final destination but leave off space preceeding number
sleepString[11+len] := CR ' ' add CR
sleepString[11+len+1] := LF ' ' add LF
sleepString[11+len+2] := 0 ' ' make sure it's zero terminated
uarts.str(debug,@sleepString)
uarts.putc(debug, CR)
repeat len from 0 to 24
uarts.hex(debug,sleepString[len],2)
uarts.putc(debug,SPACE)
Here's what I get:
len: 9 $PRTHS,COMA,80044000 24 50 52 54 48 53 2C 43 4F 4D 41 2C 38 30 30 34 34 30 30 30 0D 0A 00 00 00
Peter
Let's get this straight. You want to spit out the string "$PRTHS,COMA,86400000" followed by a carriage return and new line.
So why not just:
That assumes that whatever object "uarts" is has a "dec" method to output a decimal value as an ASCII string of digits. If it has not you will have to do that conversion first with "Num.ToStr" and just output the resulting string at that point.
Your example shows the correct looking string being output to the debug port. Does your actual device use the same baud rate?
That solved it!
There is no excuse for how I was trying to do this. I don't know how I made something so simple so complicated. Clearly that's why it didn't work.
Thanks for correcting me.
Excellent. Don't worry. I've travelled that road many times and probably will again.
numbers
and
simple numbers
this way you can convert any number in any format.
Massimo
