Propeller code help — Parallax Forums
Propeller code help
scurrierscurrier Posts: 32
edited 2010-10-18 20:24 in Propeller 1
Hello all,
I am new to the Prop and trying to make a simple program to help me understand variables, addresses, duty cycles, and cogs.
I am trying to make an object that makes a series of LEDs in a row chase each other with a light pattern. I am using the LED setup with pins 4-9 that the PE kit uses. My intention for the object is that it would start as many cogs as the number of LEDs requires counters for (one per LED) to drive duty cycles. Then, the main method just updates the variable addresses of the variables that drive the FRQ for each counter. This enables the main object to easily control how bright each LED is almost directly. But, when I run the following test code below, when I use more than one cog, I find that the LEDs whose duty cycles I am trying to adjust stutter a bit. The duty cycle seems like it is working but it seems like there is some other frequency superimposed on top of it. The LEDs also seem to be a bit dim. Does anyone see why this might be? I suspect it has something to do with my repeat loops but I am new to the Prop and I can't find the problem. Thanks for helping me out. I am loving the Prop so far!
Shaun
''DutyStream.spin
CON
  _xinfreq = 5000000
  _clkmode = xtal1 + pll16x
OBJ
  Debug:        "FullDuplexSerialPlus"
VAR
  long stack[100], ledDutyCycle[14]
PUB Main | size, index, cog[7], led[13], scale
  Debug.start(31, 30, 0, 57600)
  waitcnt(clkfreq*2 + cnt)
  Debug.tx(Debug#CLS)
  size := 6  'Specify the total number of LEDs, max of 14 (2 counters per 7       cogs)
  scale := 16_777_216
  long[@ledDutyCycle][0] := 3000000000
  long[@ledDutyCycle][1] := 3000000000
  repeat index from 0 to 1
    cognew(LightTwoLEDs(4+index*2,@ledDutyCycle[0],4+index*2+1,@ledDutyCycle[1]),@stack[index*20])
repeat
  repeat index from 0 to 255
    long[@ledDutyCycle][0] := index * scale
    waitcnt(clkfreq/128 + cnt)
PUB LightTwoLEDs(pina,dutyafreq,pinb,dutybfreq) | ratea, rateb
'Sets 2 LEDs to light with the specified duty cycle
repeat
  ctra[30..26] := %00110        ' Set ctra to DUTY mode
  ctra[5..0] := pina            ' Set ctra's APIN
  frqa := long[dutyafreq]             ' Set frqa register
  dira[pina]~~
  ctrb[30..26] := %00110        ' Set ctra to DUTY mode
  ctrb[5..0] := pinb            ' Set ctra's APIN
  frqb := long[dutybfreq]             ' Set frqa register
  dira[pinb]~~
  • T ChapT Chap Posts: 4,223
    edited 2010-10-18 00:14
    Hi Shaun
    A couple of things first off: When modifying local variables, as in your Main, you do not need to use long[@ to change the variable to the new number.
    Just refer to it like this: ledDutyCycle[0] := 3000000000
    When you get to the Repeats that will actually do the counter modification, it is not necessary to include the dira, ctra in the repeat, you can park those at the top so they run only once to start the counter and set the direction of the pin. Then, just repeat the frqa which is all that needs to get updated after the counters are launched.
    Did you try getting the code to work on one cog before trying to run it on more?
    Others will likely have some ideas well.
  • scurrierscurrier Posts: 32
    edited 2010-10-18 10:34
    Thank you so much for taking the time to check out my code. Those are some really good tips, I am anxious to try those when I get a chance. If it doesn't fix the problem at least it is good practice for keeping clean code.
    In my own troubleshooting, I did try to only run it on one cog (i used the index from 0 to 0). The problem did not occur when I did this. Strange, right? I am not sure why doing this on two cogs would be different from doing it on one.
    edited 2010-10-18 17:08
    scurrier wrote: »
    FWIW, I ran this on the demoboard with 4 cogs (8 LEDs) and I couldn't observe any kind of stutter compared to a single cog run. What kind of LEDs are you using? I seem to remember (i.e. there was a thread about this) that blue LEDs behave slightly different from yellow ones in terms of DUTY response. Other than that there is no reason why it shouldn't work.
    Thanks for that feedback. I am definitely seeing a stutter. It is very prominent when using 3 cogs as compared to using one. I incorporated the feedback from the first response above and I am still seeing it. I wonder if the power regulators have something to do with it? I pulled a, "Hold my beer and watch this," and hooked up two 9 volts in parallel just to make sure that it wasn't my Smile rayovacs that were causing the problem. Didn't seem to make a difference.
    This is definitely separate from the different duty cycle response among colors. I have noticed that too and this is a separate phenomenon. I am using 2 each of 3 colors for reference. That is what came with my kit. If I wanted to get really fancy I'd make a map that would map each brightness to a duty cycle for the individual colors, but once my propeller development board comes they are all going to be blue so there will be no need.
