How to bootload off an SD card using only one EEPROM?
Well, once again, the title pretty much sums it up. My current project(Propeller PDA) uses two eeproms for boot loading. One EEPROM holds the main control program and the other holds the new program booted up from the SD card. This method is unorthodox at best and very impractical at worst...So i guess my question is. How(In theory) can one boot off an SD card using only a single 64kilobyte eeprom? How would it work? Is there someway that one could just directly write the SD data to the ram?
I am not looking for step by step instructions, i am just looking for a general theory. I was thinking that one could load the new program into the EEPROM and before shutting off, it would load the main program back into the EEPROM. The only problem with this is that if power was removed before the system shut off correctly, the whole system would cease to function..I know a lot of people on here only use a single EEPROM, but i just can't figure out how it would work....ANY ideas
I'm planning to have a FORTH kernel in EEPROM. The kernel can be set such that the an application can be executed instead of the interactive command line.
For this case, the executed application would be the word that starts loading an executable image from a predetermined area of the SD card, similar to booting from a floppy.
I'm pretty sure one could load any executable image (forth or spin or assembler, etc) into ram, launch it on a cog, and turn off the forth boot launcher cog. FORTH disappears and the target application runs as if it were always the only program present.
Its pretty straight forward, or did I miss the point of your question?
I'm sure other file-systems can do it too. No need to learn RPN.
The only catch with the version of KyeDOS I'm using is that it is a bit slow (3-4 seconds) to do this load, but I think Kye has a more updated version that is a lot faster.
This is set up for a version similar to the demoboard, with VGA on pins 16-23, keyboard, no mouse, and sd card on pins 11-15. You can change those in the software.
If you do use this program, maybe take a look at merging in Kye's faster code.
I'm a big fan of Kye's code as it can use FAT32 and also works with all my SD cards, even the smaller ones.
Requirements are a 2gb or less SD card and 5Mhz xtal. You can grab the MIT licensed code from the project page. You can also take a look at the code for a better understanding of how it works.
If an SD card is found, it reads the filenames, and depending on the filename it will load it directly to ram and start running it, or copy it to the upper 32k of eeprom.
That is the clever bit about parallel processing. The bit that is 'executing' is in a cog that has its own local 2k of memory. Each cog can access the main hub ram. You could have up to 8 cogs all overwriting the main hub ram.
How to explain this the best? (I've rewritten the following paragraphs 4 times now).
Ok, conventional program on a conventional micro - of course it can't overwrite itself (unless we are talking self modifying code)
Consider though a small program written largely in pasm. You wrap it up with its spin loader into a .bin file, maybe it is 3k, and then download it to eeprom. On bootup, the propeller puts 3k from eeprom to ram and runs it. When it gets to the instruction that starts a cog, the prop moves the next 2k into a cog. It then starts that cog.
Once that cog is started, the program is now in the cog, so it can go ahead and overwrite the entire hub ram. The program in the cog might be something simple like flashing a led, but it could also be complicated like an sd card reader that reads 32k off an sd card into hub and runs it. Thus the code in that cog can spawn other code.
For me, the most complex one to explain is the common scenario where there is a cog that loads a spin interpreter. Because spin is written in an environment that fits into the 32k of hub memory it is possible to assume it is actually running in hub, but it actually is running in the first cog. Theoretically, the spin cog interpreter could be fetching bytes from external ram rather than hub ram (this has been discussed in other threads, as it could potentially lead to Big Spin programs that can be bigger than 32k).
I think the above explanation is correct. If not, hopefully someone will jump in and correct me!
Maybe my understanding of the Propeller and cogs is not as firm as i believed...
Edit: Added more of Ravenkallen's quote. My comment was not referring to inter-cog communications, but to the load/boot process. Mailboxes (semaphores) and handshaking in many cases are used for inter-cog communications for *any* language that can reference the mailboxes.
You might put an I2C driver in one cog. You might have a keyboard driver in another cog. Keep the protocols simple and they can all chat to each other.
However, if you look through the Obex, not many objects are coded like this. Most are a mix of Spin and PASM, and it is the spin part that causes problems with overwriting, as that does have to stay in hub ram.
If you go hunting though, you can find objects that are pure PASM. Pullmoll wrote a few that are buried in the CPM emulation, for instance. The only bit of Spin is the bit that loads the cog, and that can be overwritten. All you need then is for the postbox location to be fixed (or known as part of the load process and passed when the cog is loaded).
I think there are some pure PASM drivers in the Catalina project as well. And some objects are almost pure PASM, eg the 4 port UART and keyboard objects.
sdspiFemto can also boot from EEPROM including beyond 32K or EEPROM on other I/O pins than 28/29. It does it the same way, just reading from the specified area of EEPROM instead of an SD card. There's a similar routine for booting from a file on an SPI flash chip. Look at the Winbond/SRAM driver in the OBEX. These are all derived from the same EEPROM boot loader.
Thanks.
I just mention the 5Mhz xtal caveat because the bootloader that's flashed on the board is expecting a 5Mhz xtal. But you could update the eeprom with another value.
