Rwi B12 robot
Hey out there,
I've got an RWI B12B explorer base robot that I'd like to sell or trade. I've had it several years and I paid about 1k for it when I got it.
It's still functional with the original RWI electronics and I've got the charger and a joystick for it. You may have to make up a simple 2 conductor cable to charge the robot. I've lost the cable I received with it.
I can email any pictures needed.
Anyone interested just make an offer.
Thanks.
Thanks.
Robert
The batteries still hold a charge. I can drive it around via the joystick. It turns very slow so I think one of the drives isn't programmed properly. Unit is in good condition and the wheels aren't cracked or abused.
Thanks.
I thought about removing all the electronics and installing Parallax goodies to bring the robot up to date. I just couldn't bring myself to do it.
Below is some info I found in an old copy of Robot Explorer newsletter.
The B12B Explorer can support 40 lbs of additional experimental equipment. The robot is a three wheeled rigid suspension platform with synchronous drive. This means all three wheels drive and steer simultaneously, thus producing a robot platform which can literally turn on a dime.
Synchronous drives provide a much higher degree of positional control than standard transports. Synchronous drive platform can move in any direction at any time.
The top plate is mounted over the drive mechanics and synchronized with the wheels. The plate simultaneously changes direction with the wheels allowing any electronics mounted on the top plate to always face the direction of travel.
The B12 contains an NEC 78310 processor which frees the host computer from the tasks of managing the base movements. Using a pulse width modulated signal with feedback from optical shaft encoders the NEC monitors the drive and steering motors. It also monitors the battery voltage as well as the motor current.
The robot was made by RWI Real World Interface. I believe mine is a later model coming from the early 90's just before production was stopped on them.
My unit has the "bump" panels with micro switches under each panel to detect obstacles. Mine also has the enclosed gearing on each wheel. Early models had the gearing exposed.
I hope this info helps.
Thanks.
http://www.theoldrobots.com/Kludge.html and http://www.clemson.edu/ces/crb/labs/RoboticsLab/k2a.html (no pics from what I saw)
I would love to experiment with that drive system. Sadly, I have no time or space for another big project like that. But I'm sure you are tempting others. You may want to post your location so that anyone interested nearby could check it out and save shipping costs.
Thanks for the info. I'll keep that in mind.
I followed the link for the robot collection. What an interesting collection! Looks like that fellow has been collecting for quite some time.
I may be mistaken but I believe RWI who made the B12, B14 and B21 series robots eventually evolved into iRobot..... I think.
You are correct. The only reason I remember this is from seeing the "Valerie" Roboceptionist at CM. It was labeled as an RWI/iRobot B21r.
http://www.sellner.org/brennan/projects.html#robocept
looVax
(main objective)
To anyone interested in this robot. I would consider a trade for a 532nm laser of equal value.
Thanks.
