Hall Effect Questions
Need some electronics help. I am building a tachometer using the hall effect sensor from parallax (Melexis 90217 Hall-Effect Sensor) and the magnet (3/8 Diameter x 1/8 Thick Magnet).
First, does anyone have a simple circuit for using these ? I'm finding some pretty complex ones and all I need is 1 pulse per revolution. The one on the data sheet has some unusual components (at least according to digi-key)
I see that a fair number indicate that I need two magnets. Is that true ?
Finally, how do I identify the "south" side of the magnet ?
I'm replacing my reed switch which was dirt simple.
The data sheet shows circuits for minimum protection and automotive use. These are fairly standard components. The output signal levels will be approximately the same as the power supply.
You can determine which side is the south pole by suspending the magnet on a thread and allowing it to align with the earths magnetic field. If you have a magnet that has north and south poles marked you can use that. Opposite poles attract.
BTW: I'm using the propeller.
Take a look at page 5 of the DATA SHEET.
data sheet used is 3901090217 Rev. 009 Jun/04
from parallax hall effects page.
Vdd to 5 Volt
R1 5K ohm
C1 10nF (103 ceramic disk cap.)
10K ohm resistor between output of sensor and input pin of Propeller.
Every time the magnet passes within @3/4 inch. pin goes high.
So far I've run it up to 850 RPM, works great
Roger
Because it was replacing a reed switch and a counter, it really is just a magnet, embedded in a fiberglass/ply disk that spun over the switch. But at higher speeds (it gets to 3600rpm) the reed switch was overmatched.
I was having some trouble navigating mouser but found the components. So I should be set once those come in.
Roger: Thanks. That was a big help. I am also using a propeller but it's through the 1-wire counter. But the rest was dead on. Thanks
As an FYI, I attached some code that runs with the motorminder object (modified as noted above) to convert the sensor into RPM including low speeds where you need to track long periods between pulses.
