Powering from AC adapter
I noticed that my Propeller experiments with four 7-segments display has resulted in a depletion of 9V batteries really quick - so I might need to use an AC adapter.
I have a LM 7805 w/ heatsink as the 5.0V regulator, but my +3.3V regulator is the one from Holtek and the model is HT1033, without heatsink.
Checked the datasheet for HT1033 - the output current is 20~30mA, while the LM7805 datasheet does not show anything about the output current.
So it is safe to power the system with a LM7805 + HT1033?
By the way the +5V regulated voltage from the LM7805 is fed into the HT1033's input and the HT1033's output is to the Propeller.
I often use an LM317 for 3.3V, or a suitable LDO regulator like the LMS8117.
Since my AC Adapter's is 12V output, I need to get both voltage regulators for 5V and 3.3V which allows 12V. Which could you recommend?
This is a bit of overkill. Any 5V regulator in a TO220 package should be ok when connected directly to 12V. At most a small heat sink may be needed to help with cooling.
Forget the 12V supply and get a 7.5V ot 9V one. You won't have to mess about with heat sinks.
I'll search for a 9V adapter in my house. If not, I'll get some of that at a store nearby.
http://www.radioshack.com/product/index.jsp?productId=3875403&numProdsPerPage=60&retainProdsInSession=1
is an nice 1 amp supply with multiple voltages. It is regulated and filtered. It should come with a free Adapt-a-Plug. Get the "M". It fits all Parallax products.
Jim
A lot of the transformer type wall plug PSUs are unregulated, and dog rough on smoothing, and so have a higher output voltage than the stated one. The stated Volts usually expects the full loading current ( I do not like these types ).
The regs will expect a minimum input voltage to maintain its regulation, about 2 Volts over the output for the 7805 types. Some of the 3.3V regs have a restricted input range so always check the datasheets (or feed it from the 5V one).
