Connecting Prop to a ADC — Parallax Forums
SSkalkoSSkalko Posts: 9
edited 2010-10-19 14:38 in Propeller 1
I am working on a program to connect the Prop to a ADC (ADS7818P-ND http://focus.ti.com/lit/ds/symlink/ads7818.pdf ) not much luck so far. I am wondering if I need to use pull-up or pull-down resistors on the DATA, Clock and Enable connections between the IC and the Prop. I have a feeling I make need to invest in something like the USB oscilloscope that Parallax sells to make some head way on this.
  • LeonLeon Posts: 7,620
    edited 2010-10-15 12:21
    It uses a clocked serial interface, you don't need any pull-up or pull-down resistors. It's a 5V device so you will need series resistors to prevent damage to the Propeller inputs.
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-10-15 14:29
    A scope will save huge time and pain later - do it!
  • ChrisGaddChrisGadd Posts: 311
    edited 2010-10-19 13:01
    I've had a bit of success with that chip. The timing is very finicky; the Prop seems to miss counts when it's clocked above about 4MHz, limiting the sampling rate to about 250KHz for the full 12-bit resolution.
    I use one counter to output a continuous clock signal, use waitpeq/waitpne instructions to sync the reads, test the data line, rotate the carry flag into my result register, and store the full result in hub memory. See the attachment for more info.
    DAT   org
    ADC
              mov       dira,#$0000_0005               ' P0-Clk, P1-Data, P2-Conv
              mov       frqa,CtrFreq
              mov       ctra,CtrCfg
              mov       ADC_Add,#@Hub_Memory_1         ' Store relative address
              add       ADC_Add,PAR                    ' Add relative address to absolute address of ADC routine
    :reset
              mov       ADC_Bit_Counter,#3
              mov       ADC_Data,#0                    ' Clear ADC_Data register
    :reset_loop
              waitpne   CLK_Mask,CLK_Mask              ' Wait for clock to go low
              waitpeq   CLK_Mask,CLK_Mask              ' Wait for clock to go high
              djnz      ADC_Bit_Counter,#:reset_loop   ' Wait for three clocks
              andn      outa,Conv_Mask                 ' Clear CONV to begin data transmit
              mov       ADC_Bit_Counter,#13            ' Initialize to rotate 12 bits into ADC_Data
    :loop                                              ' Number of instructions in loop determines maximum clock rate, loop takes a minimum of four instructions
    '         waitpne   CLK_Mask,CLK_Mask              ' This line only necessary for slow clocks (already low at 4MHz)
              test      Data_Mask,ina         wc       ' Test Data pin, set C if high
              rcl       ADC_Data,#1                    ' Rotate C into ADC_Data
              djnz      ADC_Bit_Counter,#:loop         ' Loop if 12 bits not rotated in
              or        outa,Conv_Mask                 ' Raise CONV to begin sampling mode
              wrword    ADC_Data,ADC_Add               ' Store ADC_Data word at calculated absolute address of Hub_Memory_1
              jmp       #:reset
    CtrCfg           long      %0_00100_000_00000000_000000_000_000000       ' NCO, P0
    CtrFreq          long      214_748_364     ' 4MHz
    CLK_Mask         long      $0000_0001      ' CLK on P0
    Data_Mask        long      $0000_0002      ' Data on P1
    Conv_Mask        long      $0000_0004      ' CONV on P2
    ADC_Bit_Counter  long      13              ' Count 13 clocks
    ADC_Data         res       1               ' Working register for received data
    ADC_Add          res       1               ' Address in hub memory to store valid data
  • groggorygroggory Posts: 205
    edited 2010-10-19 13:21
    My saelig logic analyzer is money for this sorta stuff.
  • SSkalkoSSkalko Posts: 9
    Thanks for the help, I bought the propscope today, so that should be a big help and I will give that code a try tonight. Thanks again.
