Hall effect sensor code critique wanted
I'd like a second, third or tenth set of eyes to give these functions a quick glance over and see if there are any holes. I'm not the most efficient code writer by any means, but I would like to see if there are any holes in functionality.
This is for a 36-2 trigger wheel and hall effect sensor on an automobile.
Thanks for reading.
Thanks for reading.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
c_CrankSensorInputPin = 1
c_KeyOnInputPin = 2
c_CamSensorInputPin = 3
c_CrankSensorOutputPin = 5
c_CamSensorOutputPin = 7
c_ECUFeedbackPin = 8
OBJ
Debug : "FullDuplexSerial"
VAR
' ########### PUB Main Variables ###########
' ########### CalculateRPMs Variables ###########
long RPMCalculator
long c_WaitingforKeyOn
long CrankToothSyncCount
long SyncPulseLow
long SyncPulseHigh
long SyncPulseHighTime1
long SyncPulseHighTime2
long c_WaitingtoSyncPulses
long SyncTimeBetweenPulses
long c_WaitingtoSyncTDC
long CrankToothCount
long TDCSynced
long CrankToothPulseTime
long CrankToothTDC
long cranksensorlow
long CrankTDCTime
long c_CountingCrankTeeth
long cranksensorhigh
long CrankTimeBetweenTriggerTeeth
long CrankTDC
long CrankTimeBetweenTDCs
' ########### RPMfromCrankTrigger Variables ###########
long RPMfromCT
' ########### RPMfromTopDeadCenter Variables ###########
long RPMfromTDC
PUB CalculateRPMs
dira[c_CrankSensorInputPin] := 0
dira[c_KeyOnInputPin] := 0
dira[c_CamSensorInputPin] := 0
repeat
case RPMCalculator
c_WaitingforKeyOn:
If c_KeyOnInputPin == 1 ' If the key is on
CrankToothSyncCount := 0
SyncPulseLow := true
SyncPulseHighTime1 := 0
SyncPulseHighTime2 := 0
RPMCalculator := c_WaitingtoSyncPulses
'RPMCalculator := c_WaitingtoSyncTDC
else
RPMCalculator := c_WaitingforKeyOn
Debug.Str(string("Key is off"))
Debug.Tx(13)
c_WaitingtoSyncPulses:
If c_CrankSensorInputPin == 1 AND SyncPulseLow := true ' Initially set to low
If SyncPulseHighTime1 <> 0 AND SyncPulseHighTime2 == 0
SyncPulseHighTime2 := cnt
SyncPulseLow := false
SyncTimeBetweenPulses := (SyncPulseHighTime2 - SyncPulseHighTime1) ' If rpms are at 200 and not TDC, variable is set to 0.00833333333333 . If at TDC variable is set to 0.0166666666667
Elseif SyncPulseHighTime1 == 0 ' First time entering the loop when pin sees a high
SyncPulseHighTime1 := cnt
SyncPulseHigh := true
'RPMCalculator := c_WaitingtoSyncPulses ' Jumps out of the if statement so the following elseif will not evaluate to true in this single loop
Else
Debug.Str(string("WaitingtoSyncPulses Error"))
Debug.Tx(13)
Elseif c_CrankSensorInputPin == 0
Else
Debug.Str(string("Waiting to transistion"))
Debug.Tx(13)
' 200rpms is a tooth pulse every 0.00833333333333 (* 1.75 = 0.0145833333333)
c_WaitingtoSyncTDC: ' 400rpms is a tooth pulse every 0.00416666666667 (* 1.75 = 0.0072916666667)
' 500rpms is a tooth pulse every 0.00333333333333 (* 1.75 = 0.0058333333333)
If c_CrankSensorInputPin == 1 AND SyncTimeBetweenPulses =< 0.0145833333333 ' aka 200rpms when car starts to turn over and pin goes high
If CrankToothSyncCount =< 34 AND SyncPulseLow == true ' starts at 0
CrankToothSyncCount := CrankToothSyncCount + 1
Elseif CrankToothSyncCount > 34 AND SyncPulseLow == true
CrankToothSyncCount := 1 ' when pin goes high a 35th time (which is also the first time during another revolution)
CrankToothCount := 0
TDCSynced := true
CrankToothPulseTime := cnt
CrankToothTDC := cnt
cranksensorlow := true
CrankTDCTime := cnt
Debug.Str(string("----- TDC Sync ----- TDC Sync ----- Count Higher than 34 -----"))
Debug.Tx(13)
RPMCalculator := c_CountingCrankTeeth
Else
Debug.Str(string("Error in c_WaitingtoSyncTDC"))
Debug.Tx(13)
Elseif c_CrankSensorInputPin == 1 AND SyncTimeBetweenPulses > 0.0145833333333
TDCSynced := true
CrankTDCTime := cnt
Debug.Str(string("----- TDC Sync ----- TDC Sync -----"))
Debug.Tx(13)
Else
Debug.Str(string("Waiting to transition in c_WaitingtoSyncTDC"))
Debug.Tx(13)
c_CountingCrankTeeth:
If c_CrankSensorInputPin == 1 AND cranksensorlow := true ' when pin goes high after a low
cranksensorhigh := true
cranksensorlow := false
If CrankToothCount =< 34
CrankTimeBetweenTriggerTeeth := (cnt - CrankToothPulseTime) ' time between last crank sensor pulse and this one
CrankToothCount := CrankToothCount + 1
Else
CrankToothCount := 1 ' 1 or 35, they are both the same
CrankTDC := true
CrankTimeBetweenTDCs := (cnt - CrankTDCTime) ' when pin goes high a 35 time (which is also the first time during another revolution)
CrankTDCTime := cnt
Debug.Str(string("----- TDC ----- TDC -----"))
Debug.Tx(13)
elseif c_CrankSensorInputPin == 0
cranksensorhigh := false
else
Debug.Str(string("Waiting for transition in CountingCrankTeeth"))
Debug.Tx(13)
PUB RPMfromCrankTrigger
repeat
RPMfromCT := (((1/CrankTimeBetweenTriggerTeeth) * 36) * 60)
If RPMfromCT =< 0 OR RPMfromCT => 10_000
RPMfromCT := 0
Debug.Str(string("Error in case RPMfromCrankTrigger"))
Debug.Tx(13)
Else
RPMfromCT := RPMfromCT
PUB RPMfromTopDeadCenter
repeat
If cranktdc == true
RPMfromTDC := ((1/CrankTimeBetweenTDCs) * 60)
If RPMfromTDC =< 0 OR RPMfromTDC => 10_000
RPMfromTDC := 0
Debug.Str(string("Error in case RPMfromTopDeadCenter"))
Debug.Tx(13)
Else
RPMfromTDC := RPMfromTDC
Rich H
Thanks for the response, can you tell me why? How about the rest of it?
I could write (116666/clkfreq) but I don't think that buys me anything?
As of now, I believe the value has to be 1.75 times the length of time between each tooth's pulse at a cranking rpm of 200. If this 1.75(value) is seen, that means that TDC is reached during the minus 2 of the 36-2 portion of the trigger wheel.
I'm going to humbly ask for a laymens term explanation, because I feel like I'm missing something?
What I advise doing to keep it in integer is to multiply it by a factor of 10, so for example instead of 0.0145833333333, multiply it by 100,000 for 1,458. Then, if everything else follows through with a factor of 100,000 then instead of telling it to go the max speed of 200 rpm it would be multiplied by 100,000 to 200,000,000, but would be the equivalence of 200 rpm.
I think I have something working ... if I can test it and I get it working, I will send it to you in case you want to see what I've done.
