Basic Stamp Logic Analyzer Gate Remote code made
I need a code routine written for the result that shown below Basic Stamp Logic Analyzer Gate Remote how would I being to write this routine
Here are the photo snap shots of the output of the remote control for the Gate Opener Remote RF receiver output pin
' {$STAMP BS2}
' {$PBASIC 2.5}
Pulse PIN 15 ' pulse input pin
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
Scale CON $5 '
#ENDSELECT
time VAR Word
Main:
PULSIN Pulse, 0, time ' measure positive pulse
IF (time > 0) THEN ' if not 0
time = time */ Scale ' adjust for Stamp
DEBUG CR, DEC4 time, " us " ' display microseconds
ELSE
DEBUG CLS, "Out of Range" ' else error message
ENDIF
PAUSE 200
GOTO Main
END
Here is a sample of what I get when I run this code
35
35
04
04
35
35
04
04
35
35
and so on
How can I write something that would read this as
IF time = (35,35.04,04) THEN do something
This pattern repeat it self as long as you hold the button on the remote for the gate
' {$STAMP BS2}
' {$PBASIC 2.5}
#SELECT $STAMP
Scale CON $5 '
#ENDSELECT
time VAR Word
Main:
ELSE
ENDIF
PAUSE 200
GOTO Main
END
35
35
04
04
35
35
04
04
35
35
and so on
Your post is a little hard to follow. Are you asking for BSLA code, (which would be good to have), or are you going to supply some code?
Jim
