Power concerns
This may be a bad question but i don't know the answer. If i am using a XBee PRO 60mW Chip Antenna (XBP24-ACI-001) to wireless control two 7.5v VDC motors and i have the 6 AA battery pack as a power, do i have to worry about over volting it or ruining it in any way, if that is a problem what can i do to avoid this?
Six rechargeable cells would make for 7.2 volts, which is perfect for the motors. The XBee will require a regulated 3.3v supply.
Rich H
Your robot will need a brain of some form to receive the data from the Xbee, process it, and then control the motor drivers. If you use a Propeller based board then you just connect the XBee to that. The Propeller requires 3.3 volts so it's board will have an appropriate regulator on it.
Rich H
The same way you'd regulate any other IC...with a voltage regulator.
If you're worried about inefficiencies you could even use a switching voltage regulator.
