Another snag...I need to find something to cut PCB's
I have amassed all of the needed materials to make my first printed circuit board...
Ferric Chloride..Check
Small drill bits...Check
Nice drill.....Check
Copper clad board....Check
Method of transferring design to board....Check
A way to cut my board....OOOPS
I tried a hacksaw and the term "hack" very well described the end result. I need something to cut the boards with that is cheap(Preferably) and safe. I have seen little power saws at Lowes and i wonder if something like that would work? Or could i use something a little less invasive?
Thanks in advance..
Thanks in advance..
Rich H
http://www.amazon.com/Rockwell-RK7453-9-Inch-Band-Saw/dp/B002CJLUYM
Small boards can be clamped in a vise with the desired edge aligned to the jaw tops, then filed down flush with the jaws for a smooth, flat finish.
I wonder if i could drill several holes in the board and then snap it off like that...Of course i will need something to clean up the ragged edges...
What kind of knife is recommended?
Not one you plan on using with food would be the first criteria...
One of the large XActo types works, even better is the "box cutter" type things that hold razor blades, or the trapazoid shaped guys.
You want somthing rigid and sharp, but not too thick.
Keep in mind, you're not trying to cut through the board, just deep enough to create a stress riser so that when you do the "snap" it breaks where you want. Usually you would either clamp the curcuit board in a vice with the scribe just above the jaws, or do the snap over the edge of a table, with the scribe alighed with the edge.
John R.
Oh, and uh, use clamps for the straight edge, not your own hands...... Trust me on this one. Besides, it's nice to have both hands on the blade for control.
I just draw a pencil line with a square edge, follow the line, and then clean up the edge with a regular 'mill bastard' metal file.
I use a paper cutter (you know one of those things you sit on a table or workbench with a long levered knife)...
With the built in gridlines, alignment is easy.
The trick comes in applying force to the blade handle in a way that pushes the blade up close to the guide edge as you are bringing it down.
I've seen paper cutters give a good clean cuts every time. Practice some first on some throw away stock to learn how to position the board where you want it cut and to learn how it works.
I've tried cutting boards with a scroll saw and the blade teeth wore down completely after cutting only a few (well, maybe 4) inches. This may say more about the quality of those blades than the method, but I haven't bothered with that approach again.
Scroll saw blades are great for what they are intended for, cutting soft, non-abbrasive materials. They are specifically not hardened so that they do not become brittle, and snap everytime you put a little twist in the blade as you try and turn the work piece.
You may have better luck on a scroll saw with the "blades" that consist of a wire with abrasive adhered to it. These are meant for 360 degree cutting (you don't have to rotate the work piece to change cut direction, and with the right abbrasive, may work OK for cutting circuit boards.
John R.
Yeah, the cuts are good. The trick to it though is learning where the cut really will end up. So it takes "some practice" to get that right.
After that, as long as you keep your parts (arms, legs, fingers, well all parts of your anatomy) out of the damage path it is safe.
As has been said, I may be old enough they have to sell me pretty much whatever I want, whether or not I am responsible enough to have what I want is an unrelated question.
http://www.harborfreight.com/8-inch-bench-top-shear-brake-90757.html
Cutting boards should be much easier than cutting metal!
Robert
