Tech Info
Hi, I'm a noob when it comes to DSO type scopes, so,
what is the highest frequency sine/sawtooth/square wave that the PropScope can display ?
Will it for example show a reasonable representation of a PAL video waveform ?
I picked up that Hanno is working on software that can decode the more common types of data strings, now THAT would be a huge selling point !
Copy'nPaste
Copy'nPaste
Nobody ?
I really need this info, please :smilewinkgrin:
http://forums.parallax.com/showthread.php?t=121211
Jim
I did search, honest, but missed that one
12.5 MHz analoque waveform sound ok to me :scool:
The most I require is to look at a baseband video signal, of which the highest frequency component is about 5.5 MHz, so I can safely assume the PropScope is up to the task
Actually, reading the previous link, my understanding is to sample a waveform 10 times/bits, means that at 25 MS/s I can only sample a 2.5MHz waveform ......
Mmm, seem to have confused myself now.
David Carrier
That still beats my old Po Scope, that can only do 20 KHz :smilewinkgrin:
Many scopes have a bandwidth of about 1/10th of their sample rate, so measuring a wave at 1/10th the sample rate would still end up with half of the original voltage peak to peak. Since the PropScope bandwidth is well above the sample rate, you can accurately make measurements of any repeating wave at less than 12.5 MHz, but the image displayed will have major aliasing. For a non-repeating waves it depends on the wave form. If you have a square wave at 6.25 MHz, you are guaranteed to catch at least one measurement per period while the signal is high and one while it is low. For a sine wave, you are never guaranteed to make a measurement at the peak voltages, but the more measurements per period, the more accurate the reading.
Like I said earlier, a 2.5 MHz wave would be very clear, but that doesn't preclude higher frequency waves from being clear too, it mostly matters what you are measuring. You can try it out with just the PropScope. Set the DAC to 5.5 MHz, then switch channel 2 to display the output of the DAC. It will look the same as connecting a 5.5 MHz wave into the PropScope.
David Carrier
