Chip Extraction Procedures?
Hello there,
I've just gutted out an old radio-clock, and all it's left now it's a board with a radio circuitry, pushbuttons and a clock chip.
The thing is, the clock chip is the common-used LM8560 DIP in the earlier days of electronics, and I would like to keep it.
Unfortunately, it isn't even soldered with a socket. It is soldered directly onto the board.
Now, a question - should I desolder this casually without ever burning the chip, or must I use a hot-air rework to extract it carefully? Anyone done these before?
Practice using something you don't care about. I have replaced convergence chips for projection TV'S this way. And other IC's.
It dosen't always work, but using a hot gun can't be much better as far as heating the thing up just as much.
I forgot about the braid!.
This combined with a desoldering gun would work also!
(and heat up the device much less)
Both desoldering braid and the desoldering gun can be found at radio shack.
John R.
LMAO! That's what I call my "Child Quietator" !
I use safety glasses to avoid getting solder splashes in the eye ...
T o n y
I'll get the braid from Farnell and in the electronics stores kilometers away if I have the time. Thanks.
Thankfully, it's single sided. So I might follow the instructions you have provided.
Only one thing - they have deliberately bent four pins when the chip is inserted inside during the production. I could see the four pins slanting downwards instead of proudly standing up. I guess I need the wick already.
Lay the board on top of a glass of cool water, chip down. Heat the back of all pins simultaneously until the solder starts to flow. Tap the pins with the back of a spoon. Not too hard or you'll bend the pins. If the chip does not fall out, heat a bit more and tap again. The chip will usually just fall into the water after a couple of rounds. <<If it's an old mil spec ceramic body chip, leave the water out of the glass.>>
