Building a remote trigger for Canon Digital Rebel
I want to use a propeller to be the remote trigger for my Canon Digital Rebel camera. I found an article for making a button remote.
http://media.wiley.com/product_data/excerpt/19/07645965/0764596519.pdf
It is a passive circuit with no electricity flowing into it. Don't want to fry my camera!!!
How would I use the propeller to close this circuit? A transistor?
On page 24 of that pdf file, it shows a RELAY!!! Just replace the 555 timer with the prop, and make sure to use a relay that can operate off 3.3v. (as the entre circuit should be 3.3v, instead of 5v)
You could also possibly use an optoisolator in place of the relay.
And once you're ready for some real fun,...
http://chdk.wikia.com/wiki/CHDK
cheers
tubular
Go with relays.
I actually had this very project of making an automated remote trigger for a digital Rebel as a training task for a friend of mine who started digging into the prop.
We used two small relays just to make sure nothing ugly happened to the camera.
Worked fine.
I have a camera that can use this, its totally awesome!!!
This is why open source EVERYTHING should be the LAW.
(it opens up technologies and lets everyone access the full capabilities of the items they purchase)
heads up you may need to make the focus button happy too.
my old 10D would need both a focus and then a shutter pulse .
the 40D I had needed it too the 1D can be set to only need a shutter release ..
in MF mode shutter only should work too .
Peter
Would this work?
http://www.sparkfun.com/commerce/product_info.php?products_id=314
The autofocus concerns me as I was planning on putting the camera on manual focus since even with flash assist autofocus
doesn't do well in the dark and many times keeps the picture from even being took.
This devices maximum forward voltage shows 1.4v so it should work.
The internal schematic that the datasheet shows, looks like it should work.
But the schematic that sparkfun shows, looks like it won't.
I would say go off the datasheet schematic.
Perhaps a few more people should chime in.
From Pinouts .RU ..
I did NOT tie the Cam GND to the Opto input sorce GND as I wanted total isolation .
your lucky the rebels use a Headphone jack those Pro cam 3 pin thingys are imposable to find .. I ended up gutting a cheap trigger for rhe plug and cord ..
Like Kwinn said 5-20 mA its a small LED inside( IR or red I will guess) ... easy to drive ....
I am lucky cable-wise as I already own a remote. Connecting it with a pin header will allow me to easily put it back together when I need a button remote.
Here is a video of the photographs that I captured on the
third night of the Haunted Trail.
I took pictures in the sequence of events controlled by the propeller
program and I also triggered it by a remote.
http://www.facebook.com/video/video.php?v=10150106952440550
