BS2 with LM395
Based on a reply to an earlier post, I purchased the LM395 to use as a power transistor with built in current limiting capabilities. I tried to follow the circuits in the documentation to the best of my ability but couldn't get it to work.
I basically want to power up DC lamps and fans (current less than 0.2A per component) from the BS2 but want to make sure that if students short the output or too many components are plugged in, the LM395 is protected as is the Stamp.
Any suggestions or diagrams on how to do this ?
Al
Al
How are you trying to get it to work? Attach your program to a message.
Here is the code
Al
You didn't mention which LM395 package you're using, but check that you've got the right pinout for the package you're using.
One simple test is to disconnect the LM395 and use a multimeter to make sure the I/O pin is working right in terms of output voltage. You could also use an LED connected in place of the LM395's base and collector (anode to +12V and cathode to the I/O pin through the 4.7K resistor).
I am curious, is it possible to control the current output using a TIP120 and at the same time monitor the current/voltage on a sense resistor so that I can shut down the output on the TIP120 when current exceeds a maximum value?
Before I order stuff (I don't have any low value resistors), do you think this can work in principle?
Al
Is it as shown in my attachment?
PE - this one is common collector (emitter follower)
I was looking at the numbers on your dwg, 1-2-3, b-c-e. Is that what you're doing?
One more question: The LM395 is supposed to provide current limiting. I did short the end of the I am not sure if that is a fixed limit or it can be varied, if the latter then how can I set that limit? I would like to restrict the current to 1A max.
Thanks again to both for all your help...
Al
With a normal NPN transistor in a common emitter configuration, you can limit collector current further by adding a resistor in series with the emitter. I don't know if that will work with this device, though, since it has a more complicated internal structure.
Procedure + Wiring + Battery = Success
N.B., that tab is E.
