Propeller Sticker on the Chip
Hey there,
Is there any stickers which contains the pin labels where I can paste it on the chip itself so that I know which location and function of each pin?
I can't seem to find the template in the webpage or in the forums also, or I didn't search it thoroughly.
How to get around to printing these stickers myself too?
Thanks.
Thanks.
Be carefull on the final print dimensions, 1% error, and a bit of an angle of view, (yes I know) and an error could be made.
PS Just thinking, I presume you meen the 40 pin DIP sort. If you have a scanner then both sorts are in the Prop's datasheet.
However, from the DIP40 chip sticker "Propeller Training Kit", it seems that there is A0 to A31 printed on the sticker instead of just pin numbers, and with a black background. I remembered seeing it in the forum but I didn't manage to bookmark it.
For the printing, I'm not sure I could even use an inkjet printer, and then print it on a sticker paper, cut it and paste it directly on the chip. Anyone done that at home before?
Thanks.
Beware the added heat insulation, if you intend on pushing the Prop's loadings.
I've got some polyester stickers like what you're looking for, left over from the original PropSTICK. Email me your mailing address, and I'll send you some.
Now that Phil has put up the exact artwork I remembered, you should be ok. I am slightly confused that you want something with Pin1, Pin2, ...
This will give you the pin numbers, without counting, but the real stickers give the pin titles as in the software. Pin1 (real) is P0 etc and it gets even worst when you get to Pin13 (real) which is P8 software wise ...
It also reminds you that the power pins are that way around, and both need powering/decoupling.
It was sort of checked, just in case copyright was a problem.
Can you pls explaine here?
