Using Propellent.DLL with VS2010? — Parallax Forums
ozpropdevozpropdev Posts: 2,793
edited 2010-10-11 08:08 in Propeller 1
Hi Guys,
I am having trouble trying to interface the Propellent.DLL into my Visual Studio application.
I am using Visual Basic with Vista OS. I can get some of the simple function calls to work
such as GetLibraryVersion and GetResetSignal but get errors trying to use InitPropellent.
Using external functions in a DLL is new to me and I am a bit confused on the PChar data type. Has anyone used Propellent.DLL with Visual Basic?
  • RaymanRayman Posts: 16,310
    edited 2010-10-09 05:41
    Well, I use VC++, but I'll show you some of my code, just in case that helps:
    [SIZE=2]
    [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]typedef[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]void[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] ([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]__cdecl[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* pInitPropellentFunc)([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]long[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] WinHandle, [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]bool[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] StorePrefs, [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]char[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* RegPath);
    [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]typedef[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]void[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] ([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]__cdecl[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* pFinalizePropellentFunc)();
    [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]typedef[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]void[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] ([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]__cdecl[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* pDownloadToPropellerFunc)([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]char[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* FileName, [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]int[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] DownloadCmd);
    [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]typedef[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]void[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* ([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]__cdecl[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* pCompileSourceFunc)([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]char[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]* FileName, [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]bool[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] ShowError);
    [/SIZE]
  • ozpropdevozpropdev Posts: 2,793
    edited 2010-10-09 07:01
    Thanks for your response RAYMAN.
    I'm not very familiar with C++ so I can't compare with VB.
    My code looks like this
    Declare Sub InitPropellent Lib "c:\propellent.dll" (ByVal Winhandle, ByVal storeprefs, ByVal regpath)
    Declare Function GetLibraryVersion Lib "c:\propellent.dll" () As Integer
    Declare Function GetSerialSearchMethod Lib "c:\propellent.dll" () As Integer
    Declare Function GetResetSignal Lib "c:\propellent.dll" () As Byte
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Dim ver As Integer
    Dim ssm As Integer
    Dim rs As Byte
    Dim hd As Integer = Me.Handle
    Dim sp As Boolean = False
    Dim rp As Integer = 0
    InitPropellent(hd, sp, rp) '<-- Fails here with -> "External component has thrown an exception."
    ver = GetLibraryVersion() '<-- This works!
    ssm = GetSerialSearchMethod
    rs = GetResetSignal
    Dim msg As String
    msg = "Library version =" + ver.ToString + vbCrLf
    msg &= "Serial search method =" + ssm.ToString + vbCrLf
    msg &= "Reset signal =" + rs.ToString
    MsgBox(msg)
    End Sub
    If I remove the InitPropellent line the code after it works OK.
    There must be something simple i'm missing but my knowledge is somewhat
    limited in this area.
    Regards
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2010-10-09 07:27
    Hi, attached is the outline for 5 of the Propellent calls , enough for you to download a binary to the Propeller.
    Jeff T.
    Edit.....I noticed an error in the assigned buttons that I posted.....in my routines buttons 1 2 and 3 should be reserved for the download process , load Ram and run , load EEPROM and stop and load EEPROM and run. Just rearrange the buttons for each sub
    edited 2010-10-10 06:09
    Thanks Jeff
    I have tried your code and i'm still not getting past the "Init" stage.
    VS2010 is spitting out the following error for this line of code.
    Init(hwnd, False, y) '<- "PInvokeStackImbalance was detected"
    I also had to add the following code before the Class declaration to accept your code.
    Imports System
    Imports System.Runtime.InteropServices
    Any ideas?
    Regards Brian
  • wjsteelewjsteele Posts: 697
    edited 2010-10-10 07:05
    Attached is a working sample. It's a VS2008 VB project, but it should open and run just fine in VS2010 as well after you convert the project.
    Bill
    edited 2010-10-10 07:28
    Hi Brian, I just tried copying and pasting the code I posted (included the Imports sorry for not mentioning that) into a blank Form and it ran fine for me.
    Do you have the Propellent dll in the System32 directory and I see the variable y in there , I never had the y variable is that something you altered to suit? Did you rearrange the button assignments ( 1 2 and 3 reserved for download)
    Jeff T.
    edited 2010-10-10 19:30
    Thanks Guys
    Jeff, the Y was a typo but the real code was correct with a X. Propellent is in the System32
    folder as well.
    All button names match with your code.
    Bill, thanks for your VS2008 code sample.
    Some crazy things are happening with your code Guys.
    I loaded Bill's code into VS2010 and it converted it and "Init" works.
    But if i create a new form and copy Jeff's code, I get the same error as before.
    Looking at the code I can't see any real difference between them?
    I even tried it on another machine running XP instead of Vista with the same results.
    In the Propellent V1.2 documentation for the "InitPropellent" routine it states that
    the PChar data type is 32 bits while both your declerations use Long which in VS2010 is
    64 bits?
    Dazed and confused
    Brian
    edited 2010-10-10 22:35
    Hi Guys,
    Bill's VS2008 code that seemed to work on its own was pasted into my application
    and it is now spitting out the same error.
    I also noticed that the "glv" function has been declared with LONG yet the Propellent
    documentation shows a BYTE is returned. On the version that worked I changed this
    to BYTE and it returns "18" instead of a large number.
    It's a mystery....
    Maybe I need to change my brand of coffee?
    Regards Brian
    edited 2010-10-11 02:00
    Hooray!
    I seem to have stumbled on a fix for my error problem.
    The problem seems to be related to any sub/function that passes variables to
    the Propellent.dll.
    Based on the code you guys sent me I duplicated the <dllimport>
    command for each of my declarations that pass varaibles. For each of these I also set
    the CallingConvention to CDECL mode instead of STDCALL.
    For the string passing I also used ANSI mode rather than UNI mode and that fixed
    my string passing issues as well
    Sample code
    <DllImport("Propellent", EntryPoint:="InitPropellent", CallingConvention:=CallingConvention.Cdecl)>
    Public Shared Sub start(ByVal hw As IntPtr, ByVal sp As Boolean, ByVal rp As IntPtr)
    End Sub
    Private Declare Function gpv Lib "Propellent" Alias "GetPropellerVersion" () As IntPtr
    <DllImport("Propellent", EntryPoint:="SetLibraryPath", CallingConvention:=CallingConvention.Cdecl)>
    Private Shared Sub setlib(ByVal lp As IntPtr)
    End Sub
    To init propellent I used
    Dim ptr As IntPtr
    Dim x As String = Nothing
    hwnd = Me.Handle
    ptr = Marshal.StringToHGlobalAnsi(x)
    start(hwnd, False, ptr)
    To send string i used the following
    Dim ptr As IntPtr
    x = "c:\zzz"
    setlib(ptr)
    To receive string
    Dim ptr As IntPtr
    ptr = gpv() 'get propeller version
    x = Marshal.PtrToStringAnsi(ptr)
    MsgBox(x)
    I'm still playing around with code but this appears to have solved all issues.
    Thanks for your help and ideas guys.
    Now I can finally gets some sleep.....
    Regards Brian
    Hi Brian that is great feedback , when I wrote the code I could find little to nothing regarding the Propellent dll and VB usage , much was down to trial and error. I believe with the information that you have provided we possibly have a more stable set of dll calls. I would be interested to see the completed article.
    Jeff T.
    EDIT : I have replaced the existing declarations with DllImports and looked at your suggestions on variable size everything seems to be working as it should. I did not use the msgbox for the gpv() not sure if that is needed , overall very pleasing.
