Flower power for your micro — Parallax Forums
Dr_AculaDr_Acula Posts: 5,484
edited 2010-10-08 00:14 in General Discussion
There is an article in Nuts and Volts - website link here http://www.nutsvolts.com/index.php?/blog/post/flower_power
They are getting quite a few millivolts out of a cactus - I think up to 800mV for some plants. As the article rightly points out, if you want more volts, you need an isolated ground for each plant.
I am thinking of measuring the voltage in a tree. I have a tree that is 100 years old that had a metal tag with the name of the tree and it has grown around the tag and the tag (galvanised iron) does not appear to be troubling the tree in any way. So I wonder if one could connect permanently to a plant without injuring the plant?
If so, next question - how many milliwatts?
And could one combine this with some nifty new stepup technology from Linear http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1031,C1060,P90287
One would have to correct for any galvanic effects in the metal, so possibly zinc is out of the question for the moment. Possibly straight iron, and make sure it is iron for both the plant and the ground. Possibly gold or platinum?
Some intriguing experiments for the weekend?
    edited 2010-10-07 18:34
    The real question is just how many will it take to power one of those DracBlades....
    Robert
    edited 2010-10-07 19:04
    Hopefully I'll be able to answer that. I want to check the millivolts but also see what happens when you draw some current - how much can you draw before the volts decrease. If that experiment succeeds, then one could charge up a low leakage capacitor, and then intermittently power on a board - eg for a burst wireless transmission of some data. Even if it took all day to charge up and get a few seconds of transmission it could be useful.
    Addit: power is 0.8 microwatts from a cactus. Maybe a bit low for the quiescent current for the step up converter. Possibly enough to run a microcontroller in sleep mode though.
    It looks like trees can be used http://www.voltreepower.com/pdfs/ViasalaPressRelease_Jan2010.pdf
  • LeonLeon Posts: 7,620
    edited 2010-10-07 22:14
    I remember reading about a radio amateur trying a tree as an antenna many years ago. He got some contacts, IIRC.
    Drac: When you are connecting the trees, make sure you start downwind and move upwind - Just like Girraffes eat the trees from downwind progressing upwind. LOL
