looking for hall effect current sensor on digikey
I'm looking for a non-contact current sensor that I can use on a circuit board. Like the clamp-on current sensors, but it would be a permanent fixture. I thought they were called hall effect current sensors, but I can't seem to find them on digikey. I would prefer one with an amplifier already built in, but is not necessary.
Something like this:
http://en.wikipedia.org/wiki/File:HallEffCurrentSense.jpg
Digi 620-1190-1-ND
Manufacturer Part Number ACS712ELCTR-20A-T
What are you wanting to do with it?
I am going to use it to confirm current is flowing through an AC line. I can't tap into the wire itself, but I can run the wire through my device, so this is the logical solution.
http://www.mouser.com/ProductDetail/Tamura/L01Z600S05/?qs=sGAEpiMZZMtEmA642%2fnmDDerdvBq%2fpJS
Rich H
To use them, you basically run the current directly through the chip. Everything is handled inside so you don't need a ring.
This is the one I'm using for +/-5A:
http://www.pololu.com/catalog/product/1185
They also have versions for 0-30A and +/-30A:
http://www.pololu.com/catalog/product/1187
http://www.pololu.com/catalog/product/1186
It may make sense to pick up one of these boards from Pololu to play with and see if the chip will do what you want. The boards are only $9 or $10.
I hope this helps
http://www.mouser.com/ProductDetail/Honeywell-Microswitch/CSLA2DH/?qs=sGAEpiMZZMsPDRSCoHb1X14jKaQcUE8e30HTnTAPE2g%3d
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=480-1994-ND
But, I do like this: very simple. I see it has four ratings for voltage: 2100VAC, 184Vpeak, 1500VAC, and 354Vpeak. Which one do I go off of? I don't need UL certification, but I will be running at around 500+VAC. So what's the lowdown on that? To use this, I will have to find a safe way to access the wire, but that shouldn't be too big of a problem.
The 2100VAc, 1500 VAc are the isolation voltages from the cable to the low voltage side of the transducer. 1500 VAC is fine.
Also note that some transducers, when measuring AC put out a varying DC signal that swings from 0 to 5 volts or from -4 to + 4 as the AC wave changes. Make sure you get the version you need.
