USB thumbdrive becomes unformatted — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2010-10-08 15:26 in General Discussion
Has anyone ever experienced a drive quitting? I now have two cases of client projects experiencing the drive stopping when using them connected to a Vinculum. In one case, I do not believe the drive was ever removed from being connected to the Vinculum, in another case the drive was removed, plugged into a pc and the client listened to the mp3s that were on the drive, then plugged the drive back in. The drive stopped, then I had him plug the drive back into the pc, it said this disk is not formatted. So he reformatted, reinstalled the mp3s and it worked. Typical sandisk 4 gig drives from Radio Shack. I cannot duplicate the problem on my end.
    edited 2010-10-07 10:18
    I've heard rumors of this if you pull the drive without ejecting it on an older computer, pre-2005 computers as a guess. I've never had it happen to me though.
    edited 2010-10-07 10:24
    If a file was opened, written, then power was removed without closing the file this could happen, but it would be very unlikely.
    A bug in the program could send garbage to the Vinculum drive and cause it to write garbage to the drive.
    edited 2010-10-08 13:44
    You may have just run into a couple bad Thumbdrives. A friend of mine at work had a couple of the cheap generic ones go out and I had one go bad myself. When I took one apart and pulled up the specs on the chips used it was obvious it wasn't going to last long. Some brands are better than others.
    - Is this an application that writes to the USB drive a lot?
    - Have they tried a different brand of USB Thumbdrive?
    - As someone mentioned there could be a bug in the code that wrote garbage to the drive and trashed the data.
    - How is the project powered? Is it running on batteries or on utility power that may be subject to outages?
    Robert
    edited 2010-10-08 15:06
    I have had the same thing happen and I found that you MUST eject the drive before you remove for this not to happen:)
  • T ChapT Chap Posts: 4,260
    Thanks for the ideas.
    The drives only serve to play back mp3's, there is no "open file" process going on in the code that would require closing, mp3's are just a simple instruction to play the file. There is not writing to the drives. Basically the same as a VMusic2. I cannot find mention in the Vinculum manual a command for formatting a disk, but it could still exist.
