i remember running a dip40 for a very simple project using only one VDD and one VSS, so i wasnt sure... this project is a little tight on the front layer, i guess ill just via all of the VDDs and VSSs to the back layer and put the SMD capacitors right under the other side of the propeller.
Don't forget: you need bypass caps and a filter cap. Ideally, a ceramic bypass cap is placed near each Vdd/Vss pin pair for each IC on the board -- not just the Prop. The filter cap gets located near the voltage regulator. You will have to consult the regulator's datasheet to determine what kind and what value filter cap to use. Most regulators also require an input cap.
If you end up using a Tantalum cap at the regulator there are a couple things to consider. I've usually taken a conservative approach and use them at 1/2 of their rated working voltage. One datasheet that mentions the "added reliability" of derating the caps is here:
The other concern is with the marking. The striped end on those is usually the positive side (rarely mentioned in the datasheets) instead of just about all other components which use the striped end as the negative. That got me the first time I used these surface mount tantalum caps......
@Robert - I figured out the striped-end issue the hard way one time. Surprised to see it start smoking so quickly...
The prop will probably work if you don't connect all the VDD / VSS pins, but it is poor practice and will cause reliability issues. In a pinch - maybe. But if you're laying out a board, you should definitely connect all the VDD / VSS pins and use bypass caps (and filtering caps for the VReg, too).
For those of you who know ExpressPCB this is a simple two layer PCB using the QFP propeller on the front layer and some SMD decoupling capacitors on the back layer.
hows it look?:
[EDIT]
on the top left of the image (the two traces for power and ground) the left one is 3.3vdc and the right one is ground..
thanks for the sanity check, yea that cap at the bottom was laid out wrong.. should be fixed now. plus i thickened up the traces ;-)
@ Leon,
i agree, the board was looking a little untidy.. i spent a little time last night before i went to bed and cleaned it up some. i like that staggering idea too!
thanks everyone! and if you see anything else that is not up to par please do tell
You still have several connections between tracks with acute angles; they should meet at right angles. It looks neater and avoids acid traps when etching.
YES.
And all need decoupling's Capacitor
Thanks!
http://forums.parallax.com/showthread.php?t=122212&highlight=bypass
will these suffice http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=490-1575-1-ND
some people say to use a larger tantalum capacitor but im not sure id need it for what im doing
Yes, those should be fine.
If you use the DIP version for more projects you should really use all the VDD and VSS lines as well.
Robert
http://www.kemet.com/kemet/web/homepage/kechome.nsf/weben/3AB934DEB66DBD91852571E90068CBE4/$file/F3113_Mil_TA_SM.pdf
Robert
hows it look?:
[EDIT]
Edit: Plus make all smaller VDD, VSS traces fatter, to match to others.
Jim
You can avoid those angled connections to the pads in the lower left corner by staggering the vias.
You have an acute angle on one of the tracks where it joins the fat supply track, which should be corrected.
Mitre those right angle bends.
@ Leon,
Silkscreen Disabled:
Silkscreen Enabled:
well here it is: system control rev 1.0
this is my first real propeller project and wont be the last!!
I love when green squares/rectangles come together.
Jim
this being my first PCB it was very exciting to see it work first try!
