Basic Stamp not found
Hello all,
i have buyed a boe bot kit last week. It's amazing, but sometimes when i want to run a programm, i found two kind of problems.
- The identification failed, and i see the error "Basic Stamp Not Found"
- The identification not failed, but the stamp is not identified. I attached an image to make sense.
What is the reason of that?
Thanks a lot
Thanks a lot
When I open the Basic Stamp Editor v2.5, it shows that: COM3 Device Type: (empty) Version (empty) Loopback: yes Echo: yes
http://forums.parallax.com/showthread.php?t=126094
If I run:
counter VAR Byte
FOR counter = 1 TO 100
PULSOUT 12, 650
PULSOUT 13, 850
PAUSE 20
NEXT
FOR counter = 1 TO 200
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
END
only the first "for" is runned. Why?
There is nothing wrong with the little program you showed.
The main reasons why a Stamp is "Not Found" is that there is inadequate power or there is something wrong with the serial connection to the PC, often a defective or inadequate USB to serial adapter, sometimes the wrong USB driver is installed.
If you have the Serial version then what USB to Serial adapter are you using? Those adapters aren't all created equal. In general I try to just use ones based on the FTDI chipset. Those seem to work the best for Stamp programming and also may other applications.
If you look at the properties of the USB to Serial adapter does it show what chipset is used?
Robert
