Control speed DC Motor with BoeBot
i got the boe bot kit some time ago and now i would like to control a rc car:idea: i just bought. however i am not sure how i can control the speed of the motor as it doesn't seem that there is anything in the remote controller that can increase or decrease the speed.
do you guys have any idea in which direction i could go to get this sorted out?
thank you!
thank you!
2.) alternatively on the second one make R5 a digipot, R2 1k, and feed the PWM out into the EnA and EnB of the L298HN motor driver from the first circuit. You will need to make a code to control the digipot and the direction of the motor controller. you can find out how in the datasheets of the chips. By adjusting R4 and R6 you can achieve full 0-100% PWM
thanks!
what do you need most help on?
coding?
or how the electronics are working?
do you know about the 555 at all?
http://home.cogeco.ca/~rpaisley4/LM555.html
http://www.st.com/stonline/books/pdf/docs/1773.pdf (figure 6 shows how to operate it)
1. there is a possibility to control the speed of an RC motor using the pulsout command
what i don't know is:
1. what do i need?
2. how do i hook it up?
i've been searching around and it looks like it would be easier to just use something like this:
HERE
what do you think of that option?
The options I showed are so that the 555 and 339 picks up the task of handling the PWM. because as you know the BS2 cannot do two things at once. with the circuits I showed you you can set the direction and speed. and then the motors will stay going that speed while you tell the BS2 to check sensors or whatever. then when you need to change direction or speed you go back to the digipot and 555 and perform the necessary changes. while the L298HN handles the motor load.
