Millions and Millions of Pins — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2010-10-08 07:04 in Robotics
If you had a robot and the controlling chip had millions and millions of pins, what application(s) would you use it for?
    edited 2010-10-06 09:36
    Heating my house.
  • ercoerco Posts: 20,257
    edited 2010-10-06 11:11
    Moving sculpture: Dynamically control one of these to make continually changing shapes:
    http://www.coolstuffexpress.com/store/p/227-3D-Pin-Impression-Art.html
    500 x 424 - 69K
  • LeonLeon Posts: 7,620
    edited 2010-10-06 11:21
    1 million pins at, say, 20 mA average for each comes to 20,000 A! Where is the power coming from?
  • John R.John R. Posts: 1,376
    edited 2010-10-06 11:23
    Leon wrote: »
    I million pins at, say, 20 mA average for each comes to 20,000 A! Where is the power coming from?
    And where is the heat going to...
    edited 2010-10-06 11:51
    Keeping Phil's house warm. :)
    edited 2010-10-06 12:43
    edited 2010-10-06 12:59
    You don't need lots of pins for one of those, just a few shift registers.
    edited 2010-10-06 13:04
    Those LED cubes are cool, but also very directional because of the general shape of LEDs, their lenses and diffusers. Does anyone make a spherical, omnidirectional-view LED with axial leads, which would make construction easier?
    edited 2010-10-06 17:08
    I can envision how to build an LED globe using an arc of LED's and a micro-controller. I'd use two pins to control the motor and the rest to control the LED's. By pretending the LED's are in rows and columns you use one pin to select a row and another pin to select a column. So 36 LED's in the arc would only need 12 pins, plus 2 for the motor for 14 pins.
    But LED cubes mystify me. Even an 8 x 8 x 8 cube would seem to require an enormous number of pins. You could use one of eight pins to select the level of the cube, then then you would need 64 pins to address all the LED's within a level. Unless you could again select a row and column, but that's the part that mystifies me.
    I know charlieplexing can allow many more LED's to be addressed, but it seems unreliable.
    edited 2010-10-06 19:02
    Sorry it was very late. I should have typed:
    approximately millions and millions of pin states
    The idea is to find practical applications for 32 pins which have 1x10^15 pin states. (The state of one pin can range from on, off, or 50% biased.)
    This is all I can think of (it seems too vague)
    • Signal an external device (Robot)
    • Set up a giant matrix (LED Sculpture)
    • Display large numbers on 32 LEDs
    • Output Directions of a large map
    Thank you for your replies.
    edited 2010-10-06 22:46
    How are you generating that third state? How will it be detected?
  • P!-RoP!-Ro Posts: 1,189
    edited 2010-10-07 20:29
    IDK about millions and millions of pin states, but with thousands of pins I'd build me an android.
    edited 2010-10-07 22:07
    Leon wrote: »
    Hi Leon. Any method to get 50%, such as PWM or an external resistor divider circuit will work. Detection can happen with LEDs showing states, as in the example to read numbers, or as in states read by the chip in input mode. With so many states it seems like the method should have numerous applications.
    edited 2010-10-07 22:09
    pi'd wrote: »
    Pi'd, it appears there would be numerous robotics applications, but specifically what would you do with it?
    edited 2010-10-07 22:21
    I've seen a similar technique used in robotics - with high and low outputs used for motor direction, and the pin switched to input to stop the motor. The input state was detected with an op-amp.
    edited 2010-10-07 22:46
    For light loads (e.g. LEDs), it's even easier. The micro's output structure is already one half of an H-bridge. All you have to provide is the other half:
    http://forums.parallax.com/showpost.php?p=942590&postcount=4
    Excellent ideas.
    Are the neural net experts going to chime in too?
    An artificial neuron could be created with a simple training mode and a using mode would drive it. It would have many inputs and one output. A neuron can be trained to fire or not fire based on input patterns. When a learned pattern is confirmed, associated output becomes the current output. If the input pattern does not belong in the taught list of input patterns, the firing rule is used to determine whether to fire or not. Perhaps inputs could be trinary so neurons could be multiplied using the state method described. After that, it's very complicated.
