BASIC Stamp software cannot detect BS2
I have a basic stamp 2 on a board of education rev B (purchased 2002 but not used in many years), trying to connect it to a computer for the first time to program it.
As PCs rarely have a serial port any more, I purchased the IOGEAR HBS301 Wireless Bluetooth Serial Adapter. I successfully paired it to the PC and plugged it into the board. PC = Gateway desktop with Windows 7 64 bit.
The bs2 had been programmed before. I opened a serial port terminal on the computer (putty, com3 9600) and it immediately began outputting strings of debug text that had been programmed into the bs2 years ago. The Debug Terminal of the Basic Stamp Editor software also shows this debug output.
However, when I open the Basic Stamp Editor v2.5, it does not detect the basic stamp: COM3 Device Type: (empty) Version (empty) Loopback: No Echo: No
I also tried a brand new, unprogrammed bs2 with the same result.
Therefore I am stuck not being able to program the bs2. I wonder if it has to do with the fact that the serial connection is bluetooth. Could there be some kind of flow control that is not getting through the bluetooth? Has anyone else gotten this to work? If I buy a USB-to-serial adapter, will it fix my problem, or might it suffer from the same issue? Is this a case where I actually need a null modem cable?
Thank you very much for your assistance.
Trevor
Trevor
Thank you very much for your quick and thorough response, including the recommendation on an adapter that works (one that doesn't can be very frustrating). I have ordered your recommended part and can't wait for it to arrive.
Thanks again.
Trevor
