64bit OS - Good or bad?
Bounding off my other thread about computers, I have almost decided on this one
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6645059&CatId=4965
however seeing as most software is built around a 32 bit system, is a 64 bit system not going to run 32 bit programs, or is it only vise-versa? What are the ups and downs of a 64 bit system? And also would I need 64 bit Ubuntu?
Micro
Micro
Keeping lots of pointers as 64 bit values takes more storage and takes more execution time to manage than using 32 bit values. That's the tradeoff.
Except for memory usage (which hasn't been a problem), the only issues are programs that will not run under 64 bit or drivers that don't work. I haven't run into any of these problems on any of the machines I'm using. I wouldn't hesitate to run 64 bit - but you probably won't find problems until you try something and it doesn't work.
I did install Windows 7 32 bit on one laptop because I was unsure of whether the drivers would work under 64 bit (laptop driver availability can be harder to work with than desktop sometimes). If I had it to do over again, I would just install 64 bit.
One big advantage , or disadvantage, depending who you are, is, that 64 7 requires whql signed drivers. One thing this means for the end user is that windows keeps a copy of most drivers online, so when you plug in your printer, etc, you likely don't need a disk. The icd3 driver is an exception, but that is a custom usb device, and there was no issue getting it installed and working. FTDI drivers works fine.
I have used XP x64 (Smile), Vista 64-bit, and Windows 7 64. Early adoption was a bust. There were almost no drivers that worked on 64-bit OS and many programs had problems. Nowadays, I haven't run across more than a program or two that won't work on Windows 7 64. The ones that don't run are usually not all that important. Sometimes certain programs (like Avast, and others) have reduced functionality on a 64-bit OS.
But I have a Core i7, which means triple-channel RAM, which means memory sizes in multiples of three. So it was either 3GB of RAM (no way!) or 6GB. But on 32-bits I could only access 3GB (1GB video card) what a waste! Thus, I don't have a choice other than 64-bit OS. I have not been disappointed.
In the long run, you will be better off with the larger memory capability. We've been using 64 bit processors for ears running 32 bit software.
For example the x86 architecture supports physical address extensions (PAE) which allows for 36 bit physical addresses (considerably greater than 4GB). I know the Linux kernel uses PAE, and I just checked and so does Windows XP pro.
A 64 bit OS makes PAE obsolete, but where 64 bits shines is when a single process needs to map to more than 4 GB of virtual address space. An example would be a large database which is memory mapped.
Now I don't have a need for a 64 bit OS because a 4 GB virtual address space is fine for me. So I've stuck with 32 bit Linux and Windows. I imagine in a few years 32 bit versions will go the way of the dinos and then I'll upgrade.
Edit: I found a laptop you may like. 2x the hdd space, .1 ghz faster processor (duo, so technically .2 faster) cheaper, ubuntu. Downfall: I'm not sure if it's 32 or 64 bit, and the ram is DDR2 and not DDR3.
http://www.geeks.com/details.asp?invtid=STUDIO1745-061-LNX-16R&cat=NBB
It you need more RAM addresses, you are likely in need of a server.
If you don't need a server, there are driver availability issues as these have been slow to come out.
I have a Intel Core 2 Quad machine and initially I was very upset that it came with Vista 32 bit (I felt cheated and wondered why anyone would put a 32bit OS on a 64bit machine).
But it soon became obvious that retrofitting to existing hardware might be a key issue.
As a result of the Vista being only Chinese, I loaded Ubuntu Linux in a dual boot. Initially I loaded 64 bit and found that things either didn't run right or were not available. So now I have both 32bit Vista and 32bit Ubuntu running on the 64bit machine. And since I am not doing any heavy lifting, the computer runs well.
I suppose one day I will want the 64bit power, but I am not using even 2Gbytes of the install 4Gbytes of RAM - so why should I want or need more than 4Gbytes of RAM?
The fact that the U.S. government runs 32bit OSes on 64bit machines is a great indicator of what is really the status of development.
I suspect that if I could have gotten a Quad 32bit machine, that would have been quite adequate. And I know that everything runs faster and with less crashes in Linux. And I wonder why bother with 64bit for the usual desktop since Unicode is 32bit.
One might argue that video need the power and I do have an Nvidia card on board. But all my attempts to watch video world-wide are thwarted by limited bandwidth once I get outside Taiwan.
In sum, a 64bit desktop PC seems to be ahead of its time. Vista seemed to be excessively ambitious in trying to use the power and failed. And now Windows 7 32 bit runs nicely on my Toshiba NB-250 netbook.
Still, I don't think one must hang on to XP to live in a 32bit world. Windows 7 accepted that 32bits would be around for some time. And as usual, Linux supports 32bit and does it with 1/4th the space and running faster than MS product and any machine - old or new.
I felt that way til I tried it. 64 bit is no longer something to be afraid of, imo.
Another key thing to note is that once your RAM usage goes above 70%, performance (due to indexing) goes way down as it approaches 100%. You will find that about 82% of your RAM is the maximum Windows will allow you to use. If it still needs more, it uses virtual memory on your hard drive. Because after 80+% RAM accesses get closer in speed to hard drive accesses
What is interesting is that they only turn on PAE for their data center editions of 32 bit Windows OS's. Those 32 bit flavors can support 64 GB of physical RAM.
I specifically waited for a Core II Quad to become available as the Core II Duo's were getting bogged down with Vista. The low DRAM use may be due to the Quad and thier related cashes.
At the time, I was thinking I might want to compile Linux Kernels, which is a rather intensive process. But since Ubuntu just keeps getting easier and easier, I abandoned that ambition and am not really in need of all this power. Of course, if I was a video gamer or a video editor, I might feel differently.
In may case, the motherboard is physically limited to 4Gybtes of DRAM, so it seems 32bit is adequate.
Even if that is how it worked, you only have a few MB of cache, so there isn't much compared to the amount of RAM you use.
I just feel that at least the Core II 64bits was pretty well forced upon the consumer and I have similar doubts about the general need for 64 bit unless the world-wide web really does open up to TV on the internet. That is what I was really hoping for, and it just hasn't happened.
I might use more DRAM if I drove some of the fancy video features that Vista offered, but I have Vista Home Basic and a $700USD upgrade is out of the question. It is prettier than Ubuntu and it allows me to have all the Parallax IDEs in a Windows OS, but that is about all.
My Intel Atom powered netbook 32bit machine with Windows 7 Starter seems just as fast and was only $300USD compared to well over double that for the 64bit.
Could it be something in the mysteries of BIOS? I have no idea. Or might it be that my processors are so efficient that I just can't load up the RAM. I feel like a little old man with a Ferrari.
First was XP...on that one I had some issues with drivers and such. But the machine has dual Quad Core Xeons and 16 GBs of ram and running 32-bit would be a waste of money and resources. That machine has since been upgraded to Vista x64, then to Win 7 X64.
On my last laptop it was maxed out at 4 GB, but I still ran Win 7 x64 to see the full 4gb of ram. A 32-bit Windows OS will only access about 3.25GB of ram. (Newer 32-bit OSs show 4 GBs, but really only see ~3.25GB)
My new laptop has 12GB RAM, 980X 6 core CPU & 2 SSD in RAID-0 array. And of course it's running Win 7 x64. I have had zero issues with installs. That's not to say that older software will not have issues.
OSX was NOT 64BIT native untill recently
but it still supported 16 GIGs of RAM on a High end G5 tower .
