Best way to answer questions like this is to go to Digikey.com and search on the two part numbers. For voltage regulators look at: pinout and heat sink connections, then check the output for your voltage, match up the current capabilities then look at the input voltage range.
If all that checks out then it's a good match.
Jim-
Jim-
